Author Topic: Planet 5  (Read 2241 times)
Nordsee
Planet 5
« on: August 24, 2010, 05:22:42 pm »
I have just read in MMI this month that to get this set to Servo Reverse, one needs to do it with everything switched off, so the TX powers up in the new mode. There is nothing in the Instructions to tell you that. I assumed that my Throttle reverse was faulty and switched from Mode1 to Mode 2 to solve the problem. Thanks to MMI, I am now much wiser!
Ghost in the shell
Re: Planet 5
« Reply #1 on: August 30, 2010, 01:29:54 pm »
nordsee, i have the T5, and i think i flicked the servo reverse over with the unit still on
Go Nuclear!  you'll love it
john44
Re: Planet 5
« Reply #2 on: May 25, 2011, 10:29:30 pm »
nordsee
you are quite correct the transmitter has to be turned of to set the servo reverse. you only have to do that for the throttle channel
 It is a failsafe for aeroplanes & helicopters so the channel cannot be changed by accident while the craft is in flight.
you can switch the other channels with the transmitter on
john
john44
Re: Planet 5
« Reply #3 on: May 26, 2011, 11:09:58 am »
Sorry nordsee,
I have just re-read the instruction manual and it states, NOTE: Both the transmitter and
receiver must be switched off before changing throttle reverse function.
john
