Author Topic: T5 Confusion  (Read 10041 times)
AmbuTech
T5 Confusion
« on: August 30, 2010, 04:24:38 pm »
Having just returned to the RC boats hobby I am still learning all the new stuff!!!
I have started out, straight from the start, with a Planet T5 system. I don't use all the channels on the TX yet, but this will come on the next boat I build.
I am confused ....
I have a 5 Channel TX and a 6 Channel RX. Is there a way to add a 6th channel to the TX to enable the full capabilities of the RX.?
Rgds Ken
Prophet
Re: T5 Confusion
« Reply #1 on: August 30, 2010, 07:22:38 pm »
6th channel on the RX is for the receiver pack battery if you don't use the BEC (battery eliminator circuit) on the ESC. it has no function on the TX at all just a power impute, remember if you using up to 5 servo or 3 servos and 2 esc's that a alot of power being drawn from the esc's if you use there form of power... battery's will be dead in under 10 Min's
AmbuTech
Re: T5 Confusion
« Reply #2 on: August 30, 2010, 08:35:31 pm »
I have an R6M receiver that has "7" sets of pins marked from L to R
B 1 2 3 4 5 6
The battery connects to "B" and this leaves a total of 6 channels free for connection/control. The T5 Tx unit has only 5 control channels which leaves the 6th RX channel with nothing to do.
Rgds Ken
dodgy geezer
Re: T5 Confusion
« Reply #3 on: August 30, 2010, 08:59:47 pm »
Yes, the Giant Cod set is similar - that is a cheap 4-channel transmitter with a 6-channel receiver. The reason is that these items are built down to a price, and cheap standard parts are used where possible. It is probably cheaper to include an off-the-shelf 6 channel receiver than to go to the trouble of designing a special 4 or 5 channel receiver. They go for silly money - £25.82 for a 2.4Ghz Tx/Rx combo and £19.14 for a 35 Mhz pair!!!
 These cheap sets are not designed to be upgraded, so there is no official facility to add a channel that I know of. However, the transmitter electronics probably include 6 channels, since that's probably what the basic transmitter chip provides. I know that the Giant Cod 4 channel transmitter has a number of unused sockets on its board, and if you plug a switch into one of them, with a little bit of soldering you get a 5-channel transmitter - here is a link to the forum discussion: http://www.giantcod.co.uk/forum/viewtopic.php?f=15&t=3848
Maybe there is a Planet Users forum, and maybe they have found out how to add a channel...?
Youngat65
Re: T5 Confusion
« Reply #4 on: August 30, 2010, 09:12:04 pm »
I have had my Giant Cod four channel transmitter modded to six channel and it works fine the two extra channels could have been proportional or switched but please don't ask me how it was done cos it is beyond the comprehension of an old man like me I just know it works fine and has done so for a year now,there also appears to be little or no more drain on either the transmitter or receiver batterys
dodgy geezer
Re: T5 Confusion
« Reply #5 on: August 30, 2010, 10:14:57 pm »
I have had my Giant Cod four channel transmitter modded to six channel and it works fine...
Can you please tell us who did that for you? Was it a commercial service? 5-channel I understand, but there is no mention of a 6-channel mod on the forum....
Re: T5 Confusion
« Reply #6 on: August 31, 2010, 06:14:55 am »
I would like to know as well
Ive done the chann 5 switch mod
but cannot find the chann 6 mod
last I could find on GC forum was
that it was an ongoing investigation
of the last couple of pins on the chip
Youngat65
Re: T5 Confusion
« Reply #7 on: August 31, 2010, 09:31:51 am »
No it wasn't a commercial service it was done by a friend for me as a favour ,Sorry that's all I can tell you
Re: T5 Confusion
« Reply #8 on: August 31, 2010, 09:36:30 am »
There are actually 6 channels and a battery pack connection on the Planet Rx not 5 and a bttery pack connection. %)
Prophet
Re: T5 Confusion
« Reply #9 on: August 31, 2010, 10:04:39 am »
yes my mistake used to old rx having 5+1
Re: T5 Confusion
« Reply #10 on: August 31, 2010, 11:41:51 am »
Looks like 6+1 to me
dodgy geezer
Re: T5 Confusion
« Reply #11 on: August 31, 2010, 11:46:14 am »
No problem - knowing that it's possible is 7/8s of the solution.  If you chat to your friend you might like to give him this  URL and ask if he would like to contribute to the discussion: http://www.giantcod.co.uk/forum/viewtopic.php?f=15&t=3848
john44
Re: T5 Confusion
« Reply #12 on: June 04, 2011, 03:22:59 pm »
[/Hi , could you please tell me what the channel 5 switch mod is please, and how to do it ( wiring dia. etc).
johnquote]
Re: T5 Confusion
« Reply #13 on: June 04, 2011, 04:54:09 pm »
http://www.giantcod.co.uk/forum/viewtopic.php?f=15&t=3848&hilit=T4U+TX+mods
This is where the info is John
There is a variable rate switch mod as well
john44
Re: T5 Confusion
« Reply #14 on: June 05, 2011, 08:34:49 am »
Thanks for that Ned.
All copied ready for action.
john
triumphjon
Re: T5 Confusion
« Reply #15 on: June 06, 2011, 08:15:58 am »
all well and good copying for future use but this isnt the planet radio , its for the radio link set ! i cant see why people need to upgrade to a six by modding a four as the prices have come so well down over the last couple of years its as cheap to buy what you need outright !
treeboa
Re: T5 Confusion
« Reply #16 on: June 11, 2011, 12:28:49 pm »
had my planet tx down to make it a four stick direction spring return, noticed on part the board was what looked like a ref to the 6th channel, some empty connection areas, though how you do it is beyond me
JayDee
    • JOHN DOWD
Re: T5 Confusion
« Reply #17 on: July 05, 2011, 09:01:39 pm »
Hello,
Just had a look inside my Planet 5 Tx.
There are quite a lot of solder pads with nothing connected to them.
Most of them are named, one is called "Gyro", must be for the Heli boys.
Anybody got any Ideas ?.
John.
http://www.john-dowd.
Page created in 0.038 seconds with 21 queries.
