What about smaller set ups? If the boat was smaller, say 18" x 4"
I should point out that I am using these ESCs in boats which are around 12"-18" long, with a typical all-up weight of around 8oz including batteries. The boats don't go incredibly fast, and stop pretty rapidly when you cut the power, so I have never found the lack of reverse to be a great problem. As well as the cost, the other advantage is that they're a fraction of an ounce in weight, and measure 1"x1/2"x1/8". They can be attached directly to the back of a micro motor as if they were a suppressor...
Of course, if your requirement includes maneuverability, delicate speed control, or you have a big, high-speed boat, then these are probably not the ESCs for you. The boats I am fitting them on could be driven at full speed into something and no damage would be incurred by either party...
