Any 25Amp should do.
Spec.
The GTX-500 is a development of the GTX-480 outboard motor. Motor power is transmitted to the propeller by a flex-shaft made of V2A stainless
steel, which is stronger than that used in the GTX 480. An adaptor is supplied in the set which also allows motors of the SPEED 480 size to be fitted, in addition to all SPEED 500-size motors.This versatile arrangement makes it possible to match the new outboard motor to the modellerīs requirements. The electric motor supplied with Order No. 2371 is powerful enough to give a good performance to small electric racing boats (e.g. RED ROCKET, Order No. 2194).The outboard motor is fixed to the model boatīs transom using 2 or 4 screws, and can be adjusted in height and thrust angle.
Length approx. 120mm
Width approx. 54mm
Height approx. 155mm
Weight excl. motor approx. 96g
