god i stand more chance of plotting the course of them rubber ducks in the sea that your drifting but thats another topic in a different area.
Back on the subject of bilge pumps ,on my Brakengarth i have a problem of water seaping through the rear hatch when she buries her bottom ,so to compensate i fitted a 12v fuel pump with silicone fuel tube from a clunk in the bilge and out via a T piece over the sides which is operated from a Robbie servo switch .
so when she looks a bit low in the water i just pump her out ,as the pump motor is not shielded this has its advantage's when the JJC sound unit goes into full throttle a couple of flocks with the pump and it resets it .
The only other thing i have had to do is fit a filter in line as i broke the last pump when some muck jammed the cog's .
I did buy one of those water alarms from Maplins with the intention of fitting it in Brakengarth wired to the pump but haven't got round to it yet .
daz
