Pages: 1 [2] 3   Go Down
Author Topic: River Queen clinker built  (Read 23170 times)
Re: River Queen clinker built
« Reply #25 on: September 22, 2010, 08:05:47 am »
Hullo Bernhard...... {-) {-) ....KBIO is talking about the round brass bodied plank lifting handle rings .... %%...you know....the ones to lift the under engine side planks....... you display these in most of your model vessels >>:-( .............Derek
Bernhard
« Reply #26 on: September 22, 2010, 01:07:51 pm »
OK.... Thanks............i do them on my lathe,,with a milling cutter  in so they  be flat,,,,,,and so clue the brass pin in...
Regards Bernhard
KBIO
« Reply #27 on: September 22, 2010, 05:24:04 pm »
Good evening! :-)
Thank you Derek! ok2
Very smart Bernhard. O0 I am going to try something to do the same as I have no machine! I'll let you know if it works. But for sure, these "locks" look bright!
Regards.
Bernhard
« Reply #28 on: September 22, 2010, 07:03:06 pm »
hi........tip top......it can easy be don in a tabel drill,,,,,
Bernhard
« Reply #29 on: September 24, 2010, 12:11:23 pm »
Hi..so is the gastank ready,,,and a new littel brass oil can....,and when i move the oil bottel,,, in the littel box...it open and close the servo..and the lantern light  up
and he have get a littel friend with him...
Regards Bernhard
Bunkerbarge
« Reply #30 on: September 24, 2010, 01:26:27 pm »
As always brilliant Bernard.  Even down to the spilt oil from the oil can, fantastic attention to detail.
KBIO
« Reply #31 on: September 24, 2010, 04:41:09 pm »
Hello Bernhard! :-)
Magnifique! :-))! I wish, I have your imagination! ok2
Cheers!  :-)
pugwash
« Reply #32 on: September 24, 2010, 05:55:17 pm »
Beautifully finished Bernard but I don't like the look of that Pooch, looks like one of the banned breeds to me
Geoff
Bernhard
« Reply #33 on: September 24, 2010, 06:34:24 pm »
hi... Thanks...No No  no evil in this ones ..it is a English Bulldog...i have one in all my boats...it is real a great friend....i still miss mine...
regards Bernhard
kno3
« Reply #34 on: September 29, 2010, 12:31:46 am »
Hehe, very nice details.
mogogear
« Reply #35 on: September 29, 2010, 05:10:43 am »
I like the rivets on the boiler bands- nice touch- but all your touches are NICE!
rathikrishna
« Reply #36 on: October 12, 2010, 09:11:40 am »
A great work my friend...no words to say...
kiwimodeller
« Reply #37 on: October 12, 2010, 10:46:49 am »
Bernhard, I was just reading through the postings again and wish to add my congratulations for a great job but also a couple more questions if you do not mind? You say earlier that you are using a 60mm Rivabo propellor and from the photo it looks to be 3 blade. Is this enogh to make the engine work hard? I have a fiberglass River Queen (875mm long) from Kingston Mouldings. It is not to the standard of yours unfortunately but still fun to work on. In that I have the Graham Industries single cylinder engine with a 3 blade variable prop which is 55mm diameter and about 65mm pitch. The single cylinder engine easily drives this so I thought that for my next boat which I am going to use the Graham twin I would need a bigger prop but if the 60mm works for you I would be happy with that. Also is the boiler one of the standard Maccsteam ones or did Mike make it especially for you? Finally, where did you get the whistle? Keep up the great work. Cheers, Ian.
Bernhard
« Reply #38 on: October 12, 2010, 03:53:06 pm »
hey Ian..I have a 60 mm 4 blade Rivabo prop on now.........and  i still wenting to get my Heron back from Nick....,,on my River Queen from Kingston...i also have a Rivabo 60mm...and a Anton Cristal engine,,,work perfect.....so the Graham will easily do the job...Yes Maccsteam did this boiler to me sometimes ago... 80mm wide 130mm long..6  tube in 28 mm burner,,ca 475ml water ,,,,,,,,The whistle is from USA,,,
  http://cgi.ebay.com/Live-Steam-Engine-Authentic-Steam-Whistle-SW-4-/130441459965?pt=LH_DefaultDomain_0&hash=item1e5eeab8fd
the photo is of  of my Kingston River Queen...  on the water here    http://www.youtube.com/watch?v=6XpKv5PyREU&feature=related
Regards Bernhard
KBIO
« Reply #39 on: October 12, 2010, 08:34:14 pm »
Good evening!
Beautiful Bernhard! But tell me: have you changed the skipper??? I get lost now! :o
Cheers!
Bernhard
« Reply #40 on: October 12, 2010, 09:06:55 pm »
hi...yes   :-)  in both River Queen,,,i now have a captain  with a moving arm...........
Bernhard
« Reply #41 on: October 13, 2010, 12:47:14 pm »
,,Today i did some small oil cans ...in ca,,,1/8
Regards Bernhard
« Reply #42 on: October 13, 2010, 01:15:01 pm »
 {-) ...you know the old story Bernhard.......TOO many oil cans will make the engineer/captain do some lubrication work  <:(
Your scale image  = as expected....... :-)) ....your friend with the good memory......Derek O0
tt1
« Reply #43 on: October 13, 2010, 06:29:47 pm »
Bernhard your workmanship is absolutely amazing.  :-))
                           Regards, Tony.
david j
« Reply #44 on: October 13, 2010, 08:46:22 pm »
hi bernhard, your boat is amazing could you tell me what scale it is built in trying to imagine the size of it
many thanks davidj
Bernhard
« Reply #45 on: October 14, 2010, 06:09:17 am »
Hi...Here it is......
                                      http://www.kingstonmouldings.com/pdriverqueen.htm
 Regards Bernhard
Bernhard
« Reply #46 on: October 20, 2010, 11:32:39 am »
..So is the Regner water pump in...it will bring the water up from the lake....Test run here       http://www.youtube.com/watch?v=lvLCXf1DovY
Regards Bernhard
HS93 (RIP)
  • I cannot spell , tough
« Reply #47 on: October 20, 2010, 11:37:32 am »
Bernhard
« Reply #48 on: October 20, 2010, 11:44:15 am »
Hi...Thanks Peter...yes i have use it before...bot i have to ordre more. nice rubber tube it is...Bot the Graham is only in for the test...i still wenting for my Heron to Come back from Monahan,,Nick...so i will use copper tube,,,,
Bernhard
Bernhard
« Reply #49 on: October 25, 2010, 01:03:35 pm »
Hi.......Today i did some instrument,,,the barometer i have use some watch part to do...the glass i did on my lathe,,,it is not easy to take good photos of them
Bernhard
Pages: 1 [2] 3   Go Up
