Hi leggolon.....we can see you are jig bending & jig soldering the ???? 1/16"brass wire.......& it is progressing well However I suspect you are using a soldering iron........ Could I suggest you consider one of those baby gas butane torches & a liquid soldering flux fluid...not a paste........The soldering naturally still requires the jig setup....but produces a greatly improved smoothness in the actual soldered joint Derek
