Author Topic: planet t5  (Read 2939 times)
triumphjon
planet t5
« on: September 24, 2010, 09:53:39 pm »
i have a model that has a rotating and elevating foward gun , the rotation is via a small motor under the deck , however ive fitted a small servo to operate the elevation of the barrel , ive plugged this into the 5th channel . my problem is that wherever the switch is ie on or off the barrel will elevate BUT NOT return to its downward position ! is this a fault with the radio ?
Paul R
Re: planet t5
« Reply #1 on: October 25, 2010, 11:10:10 pm »
Hi. Have a look at the servo reversing panel bottom right hand side of the Tx on the front. Remove the tinted cover and if you look at the CH5 switch underneath, it will say either ON / OFF or SLOW / NORMAL. If switch is in OFF position simply switch to ON position, however if it says SLOW / NORMAL it will be on regardless of which position its in.
Hopefully this will help...
Paul R
triumphjon
Re: planet t5
« Reply #2 on: October 25, 2010, 11:19:52 pm »
its the slow / normal switch on this unit ,ive tried both positions on the switch in the reversing ssection of the tx . when the switch on the top of the tx is operated  the servo will only operate  in one direction , but wont return to its original position ?
Re: planet t5
« Reply #3 on: October 26, 2010, 08:49:51 am »
Plug a different servo in that channel and see what happens with that, plug the elevation servo into a different channel and see what happens.  For figuring out whether I have a problem servo or something else in the system I go one of ACTions servo swingers.
triumphjon
Re: planet t5
« Reply #4 on: October 27, 2010, 08:10:19 pm »
ive already put several servos into the receiver socket , and each one responds just the same , it works in one direction only , ok when the servo has reached its full travel but it wont return to neutral when the switch is turned to the other position !
Re: planet t5
« Reply #5 on: October 28, 2010, 10:20:41 am »
Then its either the transmitter or receiver.  Over to someone who actually knows the ins and outs of a planet t5.  Its not some obscure facility hidden in the instructions?
Re: planet t5
« Reply #6 on: October 28, 2010, 02:50:38 pm »
The fifth channel is normally there as a gear retract and gear extend switch for the fliers so default should work both ways unless your're into belly landings.
I think it's read the manual time!
