Author Topic: WTC Layout  (Read 7409 times)
gingyer
WTC Layout
« on: September 25, 2010, 08:58:52 pm »
Hi All,
I am looking for some guidance I am seting up a WTC for a sheerline Trafalgar.
when the motor starts the servos go crazy with the interferance the motor has been fitted with capasitors
the only thing jumping out at me is that the ESC is an old Electronize one with a large relay sticking out and the reciever is mounted on the reverse
side of the tray  {:-{
I am looking for some suggestions I am toying with the idea of swaping the ESC for another type
thanks
Subculture
    • Dive-in to Model submarines
Re: WTC Layout
« Reply #1 on: September 26, 2010, 11:40:13 am »
Does the ESC incorporate a BEC?
gingyer
Re: WTC Layout
« Reply #2 on: September 26, 2010, 11:42:33 am »
yes it does
ajg141
Re: WTC Layout
« Reply #3 on: September 26, 2010, 06:34:11 pm »
Colin - that is the same set up that is in my Trafalgar and I eventually had similar problems. The same thing occured on my Bruggen UB-16 althought that has an M-Troniks esc. After discussion with some AMS members I fitted a Schulze Rx and that cured the problem. They don't come cheap but it sorted my problems.
I got mine from Engel as I hadn't a clue who sold them here!
Andrew
Re: WTC Layout
« Reply #4 on: September 26, 2010, 06:48:54 pm »
Hi ya there Colin
May I ask the obvious - I wonder - have you switched the BEC off on your electronic speed controller?  The little orange and red wires which come out of the BEC should go to a switch or be twisted together - and obviously plugged in a separate RX supply to see if this cures the problem.
I myself have encountered a similar problem, with Electronize speed controllers whilst using a SANWA radio - I eventually found it was a naff servo which was giving me all the grief.
Lastly, have you tried moving your RX away from your speed controller to see if that cures the problem.
I bet you have tried all the obvious things?  But cant think of anything else at the moment.
aye
john e
bluebird
gingyer
Re: WTC Layout
« Reply #5 on: September 26, 2010, 07:31:01 pm »
spent a while on this today  {:-{ {:-{
changed the ESC used both with and without the BEC.....no difference
moved the receiver and ESC away from each other.......slight difference but back to the same after a few minutes
changed the radio gear from my old 40MHz to 2.4Ghz (I know it wont work underwater BUT it will at least let me know my radio isn't at fault)
the interference was still here but not as bad
had a careful look at the motor............new motor being ordered.....
it is a speed 500 on a gearbox although it is all fitted with a supresion kit the inside is flashing like mad and there is rust on the casing
Hopefully this will sort it  %)
Thanks for all the input and I may of missed something totally obvious so will let you know the outcome  :-))
Andrew, All going well it may be at the next sub day in Edinburgh you have but I will still bring my frigate to hunt the other subs  :embarrassed:
gingyer
Re: WTC Layout
« Reply #6 on: September 26, 2010, 07:55:05 pm »
Hi Andrew
I had a look at the schultze receiver that you suggested but it would mean a
new radio system as my 40Mhz ones are all Hitec dual conversion will try all others first
Re: WTC Layout
« Reply #7 on: September 26, 2010, 08:54:45 pm »
Hi Andrew
A dual conversion RX should just need a different crystal to a single conversion type.   Of course, if more than one company offers dual conversion types you can safely bet your best mates favourite brown boots that they will both need different crystals. The dual conversion type picks up the exact same signal from the transmitter, it just handles it rather differently to reduce unwanted signal by tuning in much tighter.  If the motor was churning out enough interference, no amount of suppression is going to cure it.  Skimming the commutator and re-bedding the brushes would probably work, but mending it with a new one is probably the most reliable option.
Probably indicates the motor warming up and generating interference more enthusiastically with run time.
gingyer
Re: WTC Layout
« Reply #8 on: September 26, 2010, 09:07:29 pm »
Thanks Malcolm
new motor is ordered and hopefully that will solve it
gingyer
Re: WTC Layout
« Reply #9 on: September 30, 2010, 10:36:22 pm »
Hi All,
Managed to swap over the motor and everything seems
to be working correctly with out any problems
looks like it has solved the problem
thanks to all the help
dgp1957
Re: WTC Layout
« Reply #10 on: September 30, 2010, 10:56:41 pm »
Guys getting back to the dual conversion Rx crystals, I have a dual conversion synthesised Rx for my sub, do I need a dual conversion crystal in my Tx?
gingyer
Re: WTC Layout
« Reply #11 on: September 30, 2010, 10:58:18 pm »
I believe so davie
dgp1957
Re: WTC Layout
« Reply #12 on: September 30, 2010, 11:02:02 pm »
Ahhhh that solves the problem, at the weekend I tried the Rx with my F16 but only had a normal crystal in it, and the Rx could lock onto it  :-))
mattycoops43
Re: WTC Layout
« Reply #13 on: September 30, 2010, 11:46:04 pm »
I didn't think you could get a dual conversion Tx crystal? I thought it was only Rx, and Tx were all the same? Feel free to correct me!
Peter
Re: WTC Layout
« Reply #14 on: October 01, 2010, 07:02:21 am »
Tx xtals are all the same, it is only the Rx xtal that is different for dual conversion systems.
Peter
Page created in 0.017 seconds with 20 queries.
