spent a while on this today
changed the ESC used both with and without the BEC.....no difference
moved the receiver and ESC away from each other.......slight difference but back to the same after a few minutes
changed the radio gear from my old 40MHz to 2.4Ghz (I know it wont work underwater BUT it will at least let me know my radio isn't at fault)
the interference was still here but not as bad
had a careful look at the motor............new motor being ordered.....
it is a speed 500 on a gearbox although it is all fitted with a supresion kit the inside is flashing like mad and there is rust on the casing
Hopefully this will sort it
Thanks for all the input and I may of missed something totally obvious so will let you know the outcome
Andrew, All going well it may be at the next sub day in Edinburgh you have but I will still bring my frigate to hunt the other subs
