Author Topic: Rubber Compound?  (Read 5817 times)
fatcat123
Rubber Compound?
« on: September 25, 2010, 09:59:40 pm »
Hi folks,
As you are aware, there are numerous fenders available on the market and these are generally vac form plastic which really dont work in my opinion.
I want to create fenders just like the real size versions with some form of rubber. I plan to make them in 2 halves using a mould and 'weld' them together with some form of adhesive etc ..
Now making the mould is fairly simple but what can i use as the rubber? I would achieve uniform thickness by either filling the mould and allowing the outer few mm to set before emptying the mould or i would make another slightly smaller mould which would be placed into the larger mould on top of the rubber.
I think, with the right material, smaller working fenders could be made and would acutally protect your models when tied up..
Any help appreciated.
Dan
gingyer
Re: Rubber Compound?
« Reply #1 on: September 25, 2010, 10:16:41 pm »
What about silicone sealants
you can get it in differant colours and types  from proper building suppliers (ie not B&Q/wickes)
fatcat123
« Reply #2 on: September 25, 2010, 10:20:30 pm »
Yes ive just thought of that - great minds think alike!
it could easily made. I think i'lll give it a go :)
Dan
Arrow5
« Reply #3 on: September 25, 2010, 10:39:54 pm »
Various grades of RTV (room temperature vulcanising) rubbers in colour are available from a few suppliers , www.tiranti.com  will also supply mould making supplies being one.  Hard or soft rubbers .
..well can you land on this?
CGAux26
« Reply #4 on: September 25, 2010, 11:50:40 pm »
Try a PM to Umi Ryuzuki.  She makes model boat fenders which are quite resilient.
stoney
« Reply #5 on: September 26, 2010, 12:02:06 am »
 Hi Dan
 I've tried making fendering for my 10th scale Trent lifeboat with a product called Sikaflex -EBT colour was spot on but it took about 2 weeks to set and it was a pig to get
out off the mould without it getting damaged ,not a success.
what boat is the fendering for ? and what scale ?
                                          Stoney
                                         Just down the road from you at Scarborough
fatcat123
« Reply #6 on: September 26, 2010, 08:00:10 am »
Hey Stoney,
Well its for a 1/12th trent lifeboat. I also have a 1/12th scale coble.
Dan
P.S, when do we see pics of your build?  :}
stoney
« Reply #7 on: September 26, 2010, 05:15:07 pm »
 Hi Dan
  Give Adrian a ring at Speedline models he does 12th scale rubber lifeboat fendering .I,ve been watching your Trent build over the last few months looking good . :-))
  There,s some pictures of mine on the post who,s building what at the moment
                                         Stoney
Guy Bagley
« Reply #8 on: February 07, 2011, 11:51:31 am »
i had some silicon fenders from cap maquette models,
they look the part in pink or white.....
not i HAD..... some
the rubber deteriorates and the silicon drops off and as its solid - its sinks..
i had a go at making my own too, - i made a mould in RTV and then cast into with a product which was part resin, part plasticiser, this gave a hardish flexible but solid fender...
 i got the stuff from amber composites....
i remember it ended up being an expensive way to go, so if you develop a new way of making them let me know !!! i'll buy some, i used solid resin ones on my coble..
fatcat123
« Reply #9 on: February 07, 2011, 11:54:49 am »
Hi Guy,
Thanks for the info. I've not looked into it anymore as ive been busy with other things.
I must see your coble, i remember sending you some photos of mine.
I'm currently in the process of making a new scratch built one measured off my mates boat. I've made a jig but just on with fettling it and what not.
Dan
john44
« Reply #10 on: February 07, 2011, 01:45:41 pm »
You can get different color silicone sealant even black from screwfix. I have used it to make fenders for my IOM yacht.
 Have you thought about using ( Polymorph ) they are poly granule/beads, you mix with hot water , pour or spoon into your mold,
 or form them by hand. You can buy it from Maplins the electronic people.
Guy Bagley
« Reply #11 on: February 07, 2011, 02:38:22 pm »
Hi Guy,
Dan
will send you pictures to your email account
fatcat123
« Reply #12 on: February 07, 2011, 02:39:58 pm »
Umi_Ryuzuki
« Reply #13 on: February 07, 2011, 08:51:43 pm »
I post my products here.
http://mysite.ncnetwork.net/res1tf1s/id12.html
The reason I created these was because I needed 120 inches of fendering, and the
bicycle tire I was folding wasn't gluing or holding together well. So I made a mold of
two six inch strips, and cast these in polyurethane. They can be glued directly to the
boat using rubberized CA glue.
