Thanks for the responses guys.
Greg - am using standard 'camping' gas, propane/butane mix
Peter/Bunkerbarge - I have altered the setting of the gas jet and used the settings recommended in the manual (they recommend a gap of 4mm), although it isn't very clear where they are measuring the gap from in the diagram included with the instructions- the end of the gas jet to...?! However as you suggest, i will give the 2mm gap between the jet and the air hole a try tomorrow and see if that helps!
Last thing guys, am i right to try and light the burner from the top of the funnel? this has worked on a previous marine boiler however as this is the first Stuart product i have owned i am wondering if there is a more tried and tested method being used... The manual suggest removing the burner on the initial test, setting it up and then lighting it, with subsequent runs being lit from the top of the funnel. I have tried this and the burner does light, however it is very awkward and involves temporarily removing the gas tank from its position in the hull in order to remove/re-position the burner...
Once again guys, I appreciate the advice (I have had some experience with model marine steam however am always ready to take onboard some tips!)
Pete
