October 06, 2026, 01:38:14 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Radio Equipment
spectrum dx6i
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: spectrum dx6i (Read 3717 times)
boatmadman
Full Mayhemer
Offline
South Cumbria
spectrum dx6i
on:
September 28, 2010, 04:20:02 pm »
Having just acquired a spectrum radio set, I find my servos wont fit in the rx, the sockets are slightly different. Is it just a case of cutting off the lip on the plug, or do I need new plugs all together?
Drkomen86
Guest
Re: spectrum dx6i
Reply #1 on:
September 28, 2010, 04:37:11 pm »
I just cut the silly little tabs off all mine, just make sure the wires correspond the correct pins (should say on the side of the reciver, mine does)
mattycoops43
Guest
Re: spectrum dx6i
Reply #2 on:
September 28, 2010, 05:25:53 pm »
+1 Plugs are either futaba type or JR type, one with tab one without. All my stuff gets detagged as and when needed. Just make sure you don't take too much off as it is easy to break through to the plug internal and weaken it. If that happens, it won't cause a problem as long as it's not being plugged and unplugged all the time.
Matt
Bunkerbarge
Guest
Re: spectrum dx6i
Reply #3 on:
September 28, 2010, 06:56:05 pm »
The Spektrum Rx's I have are labelled with +, - and signal so you should get the plug the right way round. I've had to remove a lot of the tabs as well and you do have to watch you don't damage the plug as the plastic is quite soft.
boatmadman
Full Mayhemer
Offline
South Cumbria
Re: spectrum dx6i
Reply #4 on:
September 28, 2010, 08:17:13 pm »
Done as suggested, all working just fine, thanks
keven64
Guest
Re: spectrum dx6i
Reply #5 on:
October 08, 2010, 10:59:50 am »
I also use an emery board to gently bevel the corners of the servo plugs I am plugging into my Spektrum receivers - after cutting off any uneccessary tabs.
It makes it far easier to remove the plugs without any 'jiggling'...
Keven.
Print
Pages: [
1
Go Up
« previous
next »
Radio Equipment
spectrum dx6i
