Paul,
Reasonable question
Looks like a vivid boat! Where do you aim to run it?
The reference you gave says:
Requires: (2) 7.4V, 3200mAh LiPo batteries & 4 "AA" alkaline batteries.
I guess that the 4 AAs are for the transmitter.
Forgive me if I am teaching you to suck eggs - but a bit of explanation of the "bits" of this might be helpful to others, if not to you
7.4 V is code for two Lithium Polymer (LIPO) cells in series, ie their voltage adds up to 7.4volts
3200mAh is the capacity (size of the fuel tank) and 3200 mAh means milliAmp hours.
So this is the same as 3.2Amp Hours
So (at the very simplest level) they will supply 3.2 Amps for one hour or 32 Amps for 1/10 Hour or any other combination that multiplies to 3.2
UP TO the safe limit of thos particular LiPo cells - which is expressed as something like C30 or x30 - this means they can safely be discharged at 30 times the nominal 1-hour rate (in this case 3.2Amps)
So if you got 3.2Ah cells rated at C30 they could be discharged at 30 x 3.2 Amps or about 90Amps
Right - now what is the required current for your boat? It has a 60A speed controller so the max current must be equal or less - say 50A
Which would be equivalent to about 20C or x20 - which is a "normal" type of LiPo
All the cells in the Ebay auction are C30 type and 5000mAh (5Ah) so they are over twice the capacity reccommended - so they will weigh twice as much
So please have another look around and find some close to the specified 3200mAh - they will be the right size and weight!
Do you have a LiPo charger? - you will need one
Do you have, are you able to add the right sort of comnnectors to the cells when you get them?
From the specs of the speed controller the batteries are clearly wired in series - ie both batteries of 2 cells are in series giving about 14V nominal.
I hope some of this spiel is helpful - there may well be Mayhemmers (notoriously helpfull people ) close to you who could help
andrew
