Author Topic: Leakage!  (Read 4331 times)
Ben Tickle
Leakage!
« on: September 29, 2010, 06:41:28 PM »
Does anyone know how you find where a leak is on your boat hull?
Every time i use my boat it fills up with water
Ben
Martin [Admin]
Re: Leakage!
« Reply #1 on: September 29, 2010, 06:51:35 PM »
Bath test in order here. As long as the boat fit in the bath I guess.....
Put enough water in the bath so that the boat only just floats with the batteries etc. fitted.
Leave the boat in the bath for a few minutes to see if any water gets in.
Yes: Check prop tube & Rudder post.
No: Try running the motor at slow speed and check again.
Water?
Yes: Probably your prop shaft, bearings or lock nut.
No: Push the boat gently down into the water to see stressing the hull shows up cracks.
Martin  :-))
Ben Tickle
Re: Leakage!
« Reply #2 on: September 29, 2010, 06:58:15 PM »
Hi Martin,
Thanks for your advice! I have tried it in the bath and there is no water being let in! I have also tried it running slowly and there still does not seem to be any water let in! The only thing i can assume is there are a few cracks on the gel coat, so it could possibly be this. The next question would be, how do i seal the boat as it is an apparition catamaran which you can't get your fingers in to work on it. Would epoxy seal it???
Ben
John Mk2
Re: Leakage!
« Reply #3 on: September 29, 2010, 08:10:33 PM »
Ive got an App/Cat (See my pic) Make sure the flexy is greased , the tube is sealed (Mine was loose!) rudder mount bolts are done up (mine were not!) & make sure you tape it up well (Found hockey tape good) hope this helps.
Ben Tickle
Re: Leakage!
« Reply #4 on: September 29, 2010, 08:13:32 PM »
Thanks for your advice. Yes i do have that exact boat! When you say tube, what is this?
Ben
John Mk2
Re: Leakage!
« Reply #5 on: September 29, 2010, 08:35:07 PM »
Hi Its the silver flexy tube from stinger to where to enters the hull. As its teflon coated it needs taken out sanded down (240 grit) & epoxied back back in  :-)) Took me ages to sort out ALL the snags out :(( Set up Ect Still on going now >:-o
Ben Tickle
Re: Leakage!
« Reply #6 on: September 30, 2010, 06:18:21 AM »
I am pretty new to model boating! Could you please try and explain this a little simpler?  {-)
Ben
John Mk2
Re: Leakage!
« Reply #7 on: September 30, 2010, 06:38:45 AM »
First thing is it the same boat as mine an A.R.T.R  HOR App/Cat ?
http://www.astecmodels.co.uk/catalog/index.php?cPath=97
If yes we will take it from there :-))
Re: Leakage!
« Reply #8 on: September 30, 2010, 07:25:02 AM »
If you can remove all your sensitive electrics.
Put the boat on a bench and fill it with water. Look for the leaks on the outside. This may be easier.
Outside of hull needs to be dry first.
martno1fan
Re: Leakage!
« Reply #9 on: September 30, 2010, 08:27:35 AM »
Gelcoat cracks shouldnt make a boat leak theyre just on the surface usually,most likeley water is getting in through the hatch when running fast as you say no water when sat still or running slow?.
dodgy geezer
Re: Leakage!
« Reply #10 on: September 30, 2010, 08:46:04 AM »
One useful technique may be to dust the inside of your boat with a little talcum powder and then run it for a short while. As water comes in the tracks it makes should be more visible then...
John Mk2
Re: Leakage!
« Reply #11 on: September 30, 2010, 09:03:35 AM »
It might be waters coming up the flexy cable when running at speed. If its the same boat as mine it had no grease at ALL on cable  {:-{ And motor needed to be realigned Ect Ect Was Not at all impressed with the build quality  {:-{ The running gears fine  ;) Just needed some work to get it sorted.
John Mk2
Re: Leakage!
« Reply #12 on: September 30, 2010, 09:14:43 AM »
This is what was needed.
John Mk2
Re: Leakage!
« Reply #13 on: September 30, 2010, 09:16:50 AM »
Ben Tickle
Re: Leakage!
« Reply #14 on: September 30, 2010, 05:27:25 PM »
On my boat, i have had a look at it and at one point i no it woz dropped onto the two hulls at the front end, i think some water maybe getting in hear, how do i reseal this?
Also, while im at it, i may aswell seal the cracks if someone could please let me know how to seal a boat?
Ben
Re: Leakage!
« Reply #15 on: September 30, 2010, 05:32:35 PM »
Can you post a photo of the problem bits ?
John Mk2
Re: Leakage!
« Reply #16 on: September 30, 2010, 06:10:23 PM »
this is how i fixed mine after the rudder servo broke >:-o
John Mk2
Re: Leakage!
« Reply #17 on: September 30, 2010, 06:12:03 PM »
John Mk2
Re: Leakage!
« Reply #18 on: September 30, 2010, 06:13:25 PM »
Ben Tickle
Re: Leakage!
« Reply #19 on: September 30, 2010, 06:20:39 PM »
I've taken some pics, there all pretty much illegible though! That is the right bit of the boat though (John mk2). Its a bit smashed as my dad dropped it on its nose!:(
Any advice??
Ben
Drkomen86
Re: Leakage!
« Reply #20 on: September 30, 2010, 06:21:35 PM »
nice clean fix.
I had the same damage on mine on delivary, they dropped it in postage  <:(
looks good now tho  :-)
What motor, batt and ESC are you using in yours?
the reason I ask is I am converting mine from nitro to brushless.
Ben Tickle
Re: Leakage!
« Reply #21 on: September 30, 2010, 06:29:07 PM »
I took some pics but there preety much illegible:(
Its where i go from here really?
John Mk2
Re: Leakage!
« Reply #22 on: September 30, 2010, 06:58:17 PM »
What mine ?
John Mk2
Re: Leakage!
« Reply #23 on: September 30, 2010, 07:05:42 PM »
If you mean mine  {:-{ 2700 kv exl B/L , 125 (150 burst) Amp e.s.c ,38 mm prop. 14cells (3300mah) or Lipo 6s 3000, 35c  ;)
Ben Tickle
Re: Leakage!
« Reply #24 on: September 30, 2010, 07:07:21 PM »
I don't understand what you mean??
Ben
