Author Topic: Leakage!  (Read 4326 times)
Drkomen86
Re: Leakage!
« Reply #25 on: September 30, 2010, 07:11:43 PM »
cool, what kind of speed does that give you?
Im looking at putting a 3600kv motor with a 60A ESC and a 3c 5000 Lipo, how do you think it will do?
John Mk2
Re: Leakage!
« Reply #26 on: September 30, 2010, 07:37:57 PM »
Kin fast on lipo 6s But needs to be set up right (takes time) {:-{ C of G , prop angle/height ect  %) These are fast boats (On flat water) if its windy/choppy take CARE ok2 Anyway back to Bens  leak ?
martno1fan
Re: Leakage!
« Reply #27 on: September 30, 2010, 07:44:29 PM »
Water shouldnt run up a flex when its spinning ,the direction its spinning pushes water out  so its getting in somewhere else unless as i say its coming in when boat stops.
John Mk2
Re: Leakage!
« Reply #28 on: September 30, 2010, 08:07:32 PM »
That was just an idea :embarrassed: I had a Dateline Storm (My First fast leccy) Wet behind the ears then  {:-{ Tube & Flexy worn out Water p*ssed in when boat stopped >:-o
Drkomen86
Re: Leakage!
« Reply #29 on: September 30, 2010, 08:15:41 PM »
my flexi let a little water in when stopped, what I used was a little heat shrink over the end or the brass outer tube and then shrank so it is just loose on the flexi.
worked amazingly well for me  :-))
Ben Tickle
Re: Leakage!
« Reply #30 on: October 01, 2010, 07:20:42 AM »
I have just checked for play in the flexishaft, the appears to be about 2mm of movement?
Also, if i re grease the flexi should i use copper grease???
Ben
martno1fan
Re: Leakage!
« Reply #31 on: October 01, 2010, 08:27:58 AM »
If your tube orriginally had a teflon liner maybe its now too loose?,if it just requires regreasing then use a good quallity marine grease.
Mart
http://cgi.ebay.co.uk/AQUASLIP-MARINE-WATERPROOF-GREASE-500G-TIN-WPG500-BOAT-/310207287262?pt=UK_CarsParts_Vehicles_BoatEquipment_Accessories_SM&hash=item4839cb8fde
John Mk2
Re: Leakage!
« Reply #32 on: October 01, 2010, 08:37:51 AM »
Good Stuff That  :-))
Ben Tickle
Re: Leakage!
« Reply #33 on: October 01, 2010, 05:42:33 PM »
My boat has like a plastic tube before the flexishaft.
If i was to regrease it, should i grease the outside of the tube (plastic) or grease the outside of the tube or both?
Would i be OK using copper grease or not?
John Mk2
Re: Leakage!
« Reply #34 on: October 01, 2010, 07:46:57 PM »
Just lube the flexy not to much as it causes drag  {:-{ I dont think copper will last long  :(( Use the grease we recommended  :-)) Unless someone has other ideas ?
Ben Tickle
Re: Leakage!
« Reply #36 on: October 02, 2010, 05:35:50 PM »
Fingers crossed, my boat will not let anymore water in now! I have re greased the flexi shaft and the teflon tube with spray grease. I then tried it in the bath and it didn't let any water in, even when i reved it flat out. I have also siliconed around where the cooling water enters the boat as i have a feeling that this may also be causing problems as the back end of the boat has water coming over it when slowing down.
Thanks for all your help and i will let you know the outcome tomorrow:D
Ben
Drkomen86
Re: Leakage!
« Reply #37 on: October 02, 2010, 05:58:04 PM »
just put a single strip of insulation tape over the gap where the lid meets the hull
Ben Tickle
Re: Leakage!
« Reply #38 on: October 13, 2010, 10:29:24 AM »
Hi All,
Just to inform you all i have just tested my boat with a leak. I totally submerged it in the bath for about a minute and i got abou 10ml of water in. Last time i did this it got nearly 3 whole syringes in it.
Ben
