Author Topic: Bulk Head thickness  (Read 1622 times)
segwayscotty
Bulk Head thickness
« on: October 01, 2010, 01:18:08 pm »
I am a newbee at boat building.  I downloaded free plans for a Mayflower boat.  The beam width is about 6 inches and bow to stern is about 20 inches.  How thick should I make the bulkheads?  What would be the best material for the bulkhead and the keel?
Would it be better to buy a kit for the first build just to see how they are built?  If so, what would be a good one to start with.
Thanks for any help in advance.
Re: Bulk Head thickness
« Reply #1 on: October 01, 2010, 04:52:52 pm »
Welcome aboard
I would recommend at least 3/16" if not 1/4" plywood for the bulkheads, anything less is likely to twist/bend. Keel 3/8" to 1/2" plywood. As to kit or scratch, my first was a scratch built plank on frame Brittany Trawler which came out OK. Not Gold Medal winner but I like it. However, if you feel the need for a kit go for it. You would need to pick one that uses the same technique you want to use on your Mayflower.
HTH
Doug
Page created in 0.298 seconds with 17 queries.
