Sumo glue is a polyurethane glue, theres loads of different ones so you should be able to get it or similar easily , We do a similar product called XZell although you would be better going for a flexible cyanoacrylate such as our ClearNTuff or FlexyCyano the rubber toughened flexible cyanoacrylates are far stronger, totaly waterproof and easier to use and the rubber toughened waterproof cyanoacrylates bond a wider range of surfaces.
Rubber toughened cyanoacrylate Flexy cyano ( black colour ) or ClearNtuff (clear set ) is safer , faster, stronger, fully waterproof etc you can make it set when you want with a activator spray
Polyurethane glues such as our StarLoc Xbond, our StarLoc Xzell , Sumo, gorrilla glue etc are all based on a type of polyurethane containg MDI ( Diphenylmethane diisocyanate ) ,these glues have been re classified as harmfull so that from december the 3rd they need to have loads more warnings on them and need to be sold with chemical resistant british standard gloves and we have to register them as a harmfull substance!
Weve just recalled any stock of the polyurethanes from our distributors so we can resupply meeting the new regulations before we have too
