This is going to be fun,with two of us building the same vessel basically. However,there will be quite a few differences between the two ships,with my build being a double ender,as opposed to Graf's build which has the rounded stern. The other main difference will be that I'll be using the same stepped stern as in my last two builds,rather than the sloped stern of the plan.
I'm going for a 385 motor as the powerplant for this boat,with a 25mm 3-bladed Raboesh prop,powered by a 6V 4.5A gel cell. These coastal monitors didn't require high speeds,so I think that this powertrain should be more that adequate for the job at hand.
At the moment,the carcass is in the process of drying,with the first part of the kick-up stern in place. This is not meant to be a speed build,unlike the type 24,which I needed to build and seal in under 9 days. This is going to be a much more leisurely build,or at least it's meant to be anyway,but knowing me,I'll probably race through it like **** through a goose.Anyway,it's time for a cuppa Joe,si I'll post up some pics later on,once there's really something to see.
David.
