Author Topic: switcher help  (Read 3247 times)
tonysmoke
switcher help
« on: October 03, 2010, 06:59:53 pm »
hi all and greetings from wet and windy jersey, i have a electronize switcher 48b-4w  would like to run my lights and sound with it but i have no paper work on how to connect
wires would there be help out there thanks  tonysmoke
t le b
Stan
Re: switcher help
« Reply #1 on: October 03, 2010, 07:14:36 pm »
Hi Tony. I will check out  my paperwork  and see if i have any details . Are you still planning on coming to our open day next July?
tonysmoke
Re: switcher help
« Reply #2 on: October 03, 2010, 07:31:10 pm »
Hi stan hope you are well, we are looking  to book a club trip next year we have to pick a name out of the hat as to where ,  looks like cadma doncaster show is top of members list but we will be over for five days this time so we can visit clubs and spend time with you all,  regards tony
t le b
Re: switcher help
« Reply #3 on: October 03, 2010, 07:34:00 pm »
Tony,
These switchers switch only  the pos OR neg not both so you need a "Bus Bar" system to complete the side not switched.
tonysmoke
Re: switcher help
« Reply #4 on: October 03, 2010, 10:07:25 pm »
 sorry my mate help me here a bus bar  thick or wot,
t le b
Re: switcher help
« Reply #5 on: October 03, 2010, 10:45:33 pm »
If you switch the positive side then you must have a direct connection with the negative side to all the switched functions.
Re: switcher help
« Reply #6 on: October 04, 2010, 11:23:35 am »
Looking at the Electronize picture, the unit has four relays, each having a single change-over contact.  Each set of contacts has three terminals, marked NO, C and NC.  Unpowered, C and NC are connected, when the relay is operated, C and NO are connected.  The contact doesn't care whether it is in the positive or negative line to the item being controlled, IF it is providing power to said device.  It might be that it is going to control a device by connecting two leads from the device together, without you needing to either know or care what polarity either of those leads are.
In the case of the 2 relay type, it just has bigger relays that can handle more current.
If the contact is going to supply power to the controlled device, and is inserted into the positive supply, the negative needs permanently wiring to battery negative, possibly through a terminal strip.  In trade jargon, a bus-bar, "bus" deriving from "omnibus", old meaning, "carrying everything", so it's a bar that carries all the electric.  Industrially, it would be a chunky strip of metal with terminals for connecting wire.
regiment
Re: switcher help
« Reply #7 on: October 04, 2010, 11:30:43 am »
F L J where are you
RaaArtyGunner
Re: switcher help
« Reply #8 on: October 04, 2010, 11:35:25 am »
AKA, ACTion  :-)) :-)) O0 O0
Page created in 0.05 seconds with 21 queries.
