Author Topic: Planet T5  (Read 2572 times)
Sandy
Planet T5
« on: October 09, 2010, 11:37:52 am »
New here, and keen.
Regarding this R/C transmitter and the two josticks is it correct to say that, in Mode 2, the left hand joystick has racheted motion up/down and left/right and the right hand joystick has racheted motion up/down but spring loaded motion right/left?
If this is as I assue it is, then, can the rudder (persumably the right hand joystick with left/right motion) also be converted to racheted action?
Thanks in advance.
Sandy
triumphjon
Re: Planet T5
« Reply #1 on: October 09, 2010, 06:49:30 pm »
hi sandy , sorry to disapoint you i have both my own tx and wokinkevs tx here both of which are plannet t5 sets , and i have a ratchet onnmy right stick where as kevs ratchet is on his left stick , however spare ratchets and spring kits are readily available for a couple of quid ! as for mode 1 & 2 there is a small switch inside the set so you can switch to your own preferance . hope this helps ?
pioneer
Re: Planet T5
« Reply #2 on: October 09, 2010, 10:46:13 pm »
Hi Sandy
Here is a link to the parts available for the Planet T5. The link is to Cornwall model boats site but I'm sure other outlets will be able to supply as well.
http://www.cornwallmodelboats.co.uk/acatalog/planet-5-rc-systems.html
I'm guessing it was you I spoke with at Rouken Glen this afternoon? If it was, hope to catch up again at some point. Feel free to PM if you need more info about the T5. I'm delighted with mine!  :-))
Andrew
Page created in 0.174 seconds with 19 queries.
