Last September at the Blackheath club (Steamboatphil, Alan Rayman et al), I saw a static demonstration of a steam turbine powered boat supplied by a flash steam boiler.
It was fine piece of engineering with the turbine shaft not only powering the prop shaft, but also the feed water, lub oil and fuel pumps via a large reduction gearbox (49:1?).
The turbine sounded like a gas turbine running up and threw a great plume of water a good twenty feet (7 metres) out of the pond and onto the shore.
The boat is designed as the tethered variety (see On-the-wire website) and the turbine is required to run for as along as it takes to do the five timed laps for that type of boat.
One leason learnt by the builder, so far, is to allow for lots of thermal expansion in the engine due to the very high steam conditions from the flash boiler- too tight a tolerance results in the turbine seizing up.
There are no automatic control systems, so, currently, it is a challange to run the power plant for much more than twenty seconds (though I stand to be corrected on that).
My own current approach is to experiment with a flash boiler /jet engine (see the Steam Jet Engine thread) which has great potential and has extended runs of twenty minutes. Apart from the electric water pump, there are no moving parts and the flash boiler/engine has reached 300psi (20Bar) at 720degC steam conditions.
I am currently rebuilding parts the water pump out of more robust materials and replacing the brass (which tends to melt!) in the boiler/engine with steel.
