Author Topic: Water ingress  (Read 3383 times)
Perks842
Water ingress
« on: October 17, 2010, 01:28:43 pm »
Hello all, I've had water ingress and then power completely died. The question is the boat ran for a couple or seconds when I emptied the water out but now there is no LED on the receiver and the viper 10 ESC just has a solid red LED lit constantly.
stoney
Re: Water ingress
« Reply #1 on: October 17, 2010, 02:57:18 pm »
 Remove esc and receiver from boat and place somewhere warm for a couple of days, might work again.
                                    stoney
John Mk2
Re: Water ingress
« Reply #2 on: October 17, 2010, 03:28:03 pm »
Were you running in salt or fresh water ? If salt keep rinsing it  :-) I saved a Dx6i r.x twice by doing that. Might work nothing to loss ok2
Re: Water ingress
« Reply #3 on: October 17, 2010, 03:42:53 pm »
ESC should be ok its supposed to be waterproof
Did the motor get soaked?
If so it will need drying as well.
Leave all hatches?superstructure off and keepin a warm place
Might take up to a week depending on the temperature.
This will give the servo a chance to dry out also.
Good Luck
Perks842
Re: Water ingress
« Reply #4 on: October 17, 2010, 07:40:54 pm »
Placed the receiver in the sun and all is well. The ESC is waterproof and everything is all well. thanks
Re: Water ingress
« Reply #5 on: October 17, 2010, 07:42:37 pm »
You live in Torbay, and you had SUN?????????????????????  %)
Roadrunner
Re: Water ingress
« Reply #6 on: October 26, 2010, 11:20:10 am »
find the leak and fix it... other wise your going to have that issue again! electronics can only take so much punishment with water!
Re: Water ingress
« Reply #7 on: October 26, 2010, 11:27:35 am »
Just spent the first week of October in Brixham and SUN every day
Number 6
Re: Water ingress
« Reply #8 on: October 26, 2010, 12:20:32 pm »
I sunk my fishing trawler (well a gust of wind did) earlier this year, it spent a good hour on the bottom. When got it out and home I stripped all the electrics out, rinsed them off in clean water, nothing to loose by then and wanted to get rid of any nasties from the lakewater. Able to split the receiver casing (was using one from DX6i) and put everything in the airing cupboard for couple of days. All worked fine when reassembled, receiver, mtroniks controller, servo, decaperm motor, battery, the lot. Think I was lucky, only casualty was one deck figure that suffered burial at sea! I was just fortunate that it capsized only couple of feet from lakeside, couldn't see it though as about five foot deep and murky, got it out with adapted fishing pole with hook on end that one of our sailors keeps in his car! All good fun...Dave.  :embarrassed:
Perks842
Re: Water ingress
« Reply #9 on: October 26, 2010, 05:49:17 pm »
Dont call it the english riviera for nothing, been mainly sun for 2 months since today and as Ned says too.  %%
HS93 (RIP)
  • I cannot spell , tough
Re: Water ingress
« Reply #10 on: October 26, 2010, 05:51:28 pm »
viper 10 ESC are sealed and supposed to be  waterproof according to the makers
Peter
Perks842
Re: Water ingress
« Reply #11 on: October 26, 2010, 05:55:56 pm »
all was well in my case, the receiver just needed drying out in the sun. Viper 10 =  :-))
Page created in 1.191 seconds with 21 queries.
