Author Topic: Help how to fit a bow thruster.  (Read 2555 times)
stew49
« on: October 20, 2010, 09:55:51 pm »
HI I am building a Loyal class tender, and wondering about fitting a bow thruster. or should i leave it as is. ps im a beginner.
CGAux26
Re: Help how to fit a bow thruster.
« Reply #1 on: October 21, 2010, 12:52:20 am »
I am building a Loyal, too, and have installed a Raboesch bow thruster.  It's their second smallest size.  Pictures attached show a bit of the process.  I cut the initial holes with a hand held drill, then opened them to fit the BT tubes with a Dremel grinding tool.  I made a small block to support the BT while the 2 part epoxy putty set, and left it in place.  Excess length of about 1/8" was left on the tubes to be filed off once the putty cured.  I filled the gaps around the outside the with the same putty and sanded it smooth.
The BT is positioned right under the smallest, forward hatch, so the 3 screws holding the motor to the base can be removed with a long Phillips screwdriver.
I had trouble with the flat impeller on the BT coming loose early in its life.  I replaced the impeller with one made of brass stock, epoxied to the motor shaft.  A Proboat ESC completes the installation.  Oh, yeah, the boat has a single 6 volt SLA battery.  It kicks the bow around very nicely, at zero forward speed, good for docking and such.
stew49
« Reply #2 on: October 21, 2010, 08:12:38 am »
Thats great, don't look to hard to set up. thanks for the reply. hope your build goes well.
   many thanks  Stewart :-)
rathikrishna
« Reply #3 on: November 07, 2010, 10:31:14 am »
Friends..i am using a centrifugal pump,made out of foam board.so i saw here an alternate setup..can anyone post some internal diagrams here..?..please..
