Author Topic: Express yacht windstorm 45  (Read 16207 times)
Abfil
« on: October 25, 2010, 08:39:04 pm »
Hello
I m show you the built of my second boat. It’s an express cruiser of 45 feets. I m inspire of the spider of Cantieri di sarnico. I m made it with my son Lucien.
After a modeling on delftship I drawing on autocad alls plans of pieces, kell, and sections in first.
The modeling
The outside view
The pieces
Abfil
Re: Express yacht windstorm 45
« Reply #1 on: October 25, 2010, 08:45:47 pm »
I built keel upward. There re 7 sections in plywood in thickness 5 mm. The keel is made with 2 pieces of plywood 5 mm. Notches are cut for piece of wood 5x5 mm for consolider.
Bye
Philippe
gwa84
« Reply #2 on: October 25, 2010, 10:37:01 pm »
nice work would like to see more  :-))
Abfil
« Reply #3 on: October 26, 2010, 10:23:01 am »
Hi everybody
Thanks !
Here is now the pose of pieces 5x5 mm. There re only 4. Two for the corners and two for the deck plate.
The floor of bath is stiked behind the first section with fobs.
For the bow, I could not to arch the piece. It’s too little. Then I cutted plywood with the good shape. I added fobs in same material.
Bye
PS adress of plans
http://plansmodelismeyacht.blog4ever.com/blog/index-333923.html
martno1fan
« Reply #4 on: October 26, 2010, 03:14:20 pm »
Very nice work my only concern is the thickness of ply your using as it might end up a tad heavy,might be something to think about but nice work all the same  :-)).
Mart
Abfil
« Reply #5 on: October 26, 2010, 03:28:01 pm »
With the software delftship I calculated a weight of 1,9 Kg . I m not afraid. I think use accus less heavy than battery. I wait after the pose of hull for weigh it.
Abfil
« Reply #6 on: October 27, 2010, 12:03:19 pm »
hello, the continuation ..
Now that the skeleton is very stiff, I pursue with the pose of hull. There re 4 boards. 2 for bottoms and 2 for sides. I m begin with bottoms and after sides
First botton
Second botton
The pose of sides is more dificulte because the bow is very waisted. I m put in water the wood for soften it
Before of to stick top of hull Lucien sand that who exceed.
Bye
PS adress of plans
Abfil
« Reply #7 on: October 29, 2010, 10:07:35 am »
Hello
Now, we are going to put other pieces of wood 5x5 for access to the front of boat. There is 4. We added also a section in alft of the floor of bath.
Tne little board stick on. We used paper size for drawing it correctly.
Bye
PS adress of plans
martno1fan
« Reply #8 on: October 29, 2010, 02:33:29 pm »
Very nice work
Abfil
« Reply #9 on: November 03, 2010, 11:29:17 am »
hello
Now I m stick pieces of access to  the bow. There re built in 4 parts. It's board of samba in tickness 2 mm
Then I m start the bath board. It s easy to make. 2 boards, up and down and between fobs cut not parallel
The suburd is dress with a lot of pieces of wood and after sanded
Under I have stick a board the aesthetics
Bye
PS adress of plans
Abfil
« Reply #10 on: November 05, 2010, 07:45:38 pm »
good evening
I show you, now, the built of the stern. It s enough difficult to do. I use a lots of pieces.
I start by pose the low part
Then I make the block at port and  starboard
After I stick a piece in forme of U. It's the outline of the sun mattress
Bye
PS adress of plans
steamboatbob
« Reply #11 on: November 06, 2010, 11:51:53 am »
fantastic build mate hope it all goes well for ya :-))
Abfil
« Reply #12 on: November 08, 2010, 07:54:59 pm »
Hi guys
This is the continuation of stern
Pose of the base of the staircase
stick flask of staircaise
beginning of pose of stern
Bye
Philippe
Abfil
« Reply #13 on: November 09, 2010, 07:49:09 am »
Hi guys
Bye
Philippe
Abfil
« Reply #14 on: November 13, 2010, 05:42:47 pm »
hi
I have just finish the stern !
Every piece of wood have been sand for his place ! I do still the step of staircase
 the result ! I m enough satisfied
Bye
PS adress of plans
Abfil
« Reply #15 on: November 17, 2010, 03:19:24 pm »
hi guys
now I begin the cockpit . I start by floor and faces. After I cut pieces of roof. And for finish I start the pose of board
stick of all pieces of cockpit and roof
 stick of wood rod
 Pose of the biggest board of roof
Practically all the boat is equipped
Bye
Philippe
PS adress of plans
Abfil
« Reply #16 on: November 30, 2010, 10:21:11 am »
Hi !
The work go slowly, it's more difficult now. I stick boards of roof and outside face of cockpit. A lot of surfaces are convex. I need many pieces.
Bye
Philippe
PS adress of plans
Abfil
« Reply #17 on: December 19, 2010, 06:31:11 pm »
Hello everybody
This is the last progress on my boat. I just finish the top of cabin.
Bye
Philippe
PS adress of plans
gwa84
« Reply #18 on: December 19, 2010, 10:19:26 pm »
just so excellent work im loving watching this come together cant wait to see a finished ship sailing away
Abfil
« Reply #19 on: January 08, 2011, 04:35:55 pm »
Hello guys
I make the windscreen with pieces of wood.
It's very oblique like that the boat is more sport. It go faster  {-)
At this time the two main pieces of boat are built: The hull and the roof and cockpit.
I can start to begining the arrangement.
In first I assemble sats of sofa,
then I make all the pillows.
After I make sideboard kitchen.
It begin to look like at a cruiser !
Bye
PS adress of plans
Abfil
« Reply #20 on: January 20, 2011, 06:16:23 pm »
Hello
I  continue the built and I finish the inside of cockpit. The sofa on port, the stage and armchair of driver and the dashboard !
It's a little job, but all thinks are longer to make !
Here are the images
The stage of post piloting
The port sofa
Armchair driver
The dashboard
Pose to white
Bye
PS adress of plans
w3bby
« Reply #21 on: January 20, 2011, 09:12:33 pm »
Love watching the progress on this build :-)) :-)) :-)) Far more patience and skill than I could ever put into a project O0 O0 O0 Looking forward to seeing the finished boat and the running vids.
Must say I'm surprised by the lack of feedback from the "regular" contributors............
Abfil
« Reply #22 on: January 21, 2011, 07:40:27 am »
Yes me too, but it's like this today. There more people interessing to take then to give .... And I think, a lot of people begin a construction and they are not the patience and experiment. It's seem easy to built a model but we must do the think one after one.
Bye
samuelmerry
« Reply #23 on: January 21, 2011, 04:16:15 pm »
Very nice, I do not build this kind of boat but after the last couple of comments I felt I had to say something!!! ok2
You are clearly very skilled at what you do!
Looking forward to seeing the finished model.
martno1fan
« Reply #24 on: January 23, 2011, 08:45:18 am »
Sory i havent comented for a while but as i said before very nice work,i also like the blue boat did you build that one too  :-)).Keep up the good work.
Mart
