Author Topic: Apparition!  (Read 4087 times)
Ben Tickle
Apparition!
« on: October 29, 2010, 03:32:56 pm »
With my apparition i noe have it fully functional, however i was wondering if i was going to go brushless what would an ideal motor be? Also what ampage of esc would i need?
Ben
F1 madness
Re: Apparition!
« Reply #1 on: October 29, 2010, 05:13:09 pm »
I would try a leopard 4070, 2200Kv on 4s lipo with a 42mm prop and run a 200amp esc.which im doing at the right price :-))
brodjack
Re: Apparition!
« Reply #2 on: October 29, 2010, 08:08:06 pm »
Mine has a Medusa 3680-1600V2SE,will run on 5S lipo..and occasionally on 6S.Etti 150 Esc with extra cap. bank.
Ben Tickle
Re: Apparition!
« Reply #3 on: October 29, 2010, 09:33:35 pm »
Thanks for the advice! Could you please advise me where i can purchase either of these setups from?
Ben
F1 madness
Re: Apparition!
« Reply #4 on: October 30, 2010, 09:03:10 am »
The Leopard motors are from Astec models and hes got the cooling jackets aswell and also the motor mount for motors aswell
as for esc i can get you the esc at the right money
Ben Tickle
Re: Apparition!
« Reply #5 on: October 30, 2010, 09:37:59 am »
Ive spoken to the guy at astec models, he says that a 5xl motor is the one to go for and thats approximately £50. Which speed controller would i need for this?
Ben %%
John Mk2
Re: Apparition!
« Reply #6 on: October 30, 2010, 12:01:03 pm »
Go for the BEST one you can afford  ok2 As amps go what will hold a a lot will hold a little.
Ben Tickle
Re: Apparition!
« Reply #7 on: October 30, 2010, 07:25:02 pm »
Hi John,
As you have helped me in the past, please may i ask what motor you have in yours?
aLso, what ampage esc are you running?
Ben
John Mk2
Re: Apparition!
« Reply #8 on: October 31, 2010, 06:23:01 am »
Its out of the box  A.R.T.R  from Astec 2770kv motor Suppo 125amp E.S.C  35mm metal prop running on 4s 3000mah. I had to put 1.5 kilos of lead in to calm it down a bit :o As it kept taking  off !
Ben Tickle
Re: Apparition!
« Reply #9 on: October 31, 2010, 06:29:03 am »
I think what i will do is first save then buy a motor from as tec and everything to mount it and cooling system and then i will buy a cheap esc from eith giant cod or f1 madness!
Ben
John Mk2
Re: Apparition!
« Reply #10 on: October 31, 2010, 07:11:06 am »
Just make sure you program the E.S.C for the cell numbers/type , timing ect/ Or it might well all end in tears {:-{ Oh & DON'T over prop !
Ben Tickle
Re: Apparition!
« Reply #11 on: October 31, 2010, 07:39:39 am »
Hi John,
My boat has a metal prop on it! I think its an octura 1 and it measures 3cm from one blade to the other. And regarding esc's i was going to either get a giant cod 200amp or one of f1 madness.
Ben :D
John Mk2
Re: Apparition!
« Reply #12 on: October 31, 2010, 07:44:42 am »
Ben Tickle
Re: Apparition!
« Reply #13 on: October 31, 2010, 09:17:35 am »
The only possible problem may be that the esc is not programmable but can accept lipo batterys from 1-7 cells?
Ben
John Mk2
Re: Apparition!
« Reply #14 on: October 31, 2010, 12:45:53 pm »
My E.S.C can be programmed  From 4s - 8s. Ran it this morning & it's MORE than fast enough on 4s :o
Ben Tickle
Re: Apparition!
« Reply #15 on: October 31, 2010, 01:58:27 pm »
i think if it can have 1-7 cells then it should be fine, cayse i dont want lipos sitting around that are not suitable for my boat:D
Ben
Page created in 1.272 seconds with 19 queries.
