Author Topic: Model reconstruction BISMARCK 1/100th scale  (Read 11187 times)
Bernd
« on: October 31, 2010, 11:31:31 am »
sorry - there seems to be a Bismarck influenza around ....  ok2
Ten years ago I started my research on BISMARCK and on christmas 2006 I started to cut the first parts . It will be a scale reconstruction and a static model of the March 1941 status of the ship. I researched and collected quite some material on BISMARCK over the last decade and I base my reconstruction soley on this material.
I started with two artillery command post, a few details are still lacking. Hope you´ll like it! :-)
Artillery command post located in the foretop (Aluminum sheet, brass, styrene):
Bernd
Re: Model reconstruction BISMARCK 1/100th scale
« Reply #1 on: October 31, 2010, 11:36:53 am »
A few parts (PE parts) are still missing. I also need to finish the camouflage.
Bye!
Bowwave
« Reply #2 on: October 31, 2010, 01:43:28 pm »
 Oh boy when you see two eye watering model builds  of the same subject a third turns up %% :o :-))
Bowwave
Norberto
« Reply #3 on: November 01, 2010, 11:50:56 am »
superb quality as always :-))
Bernd
« Reply #4 on: November 10, 2010, 08:08:58 pm »
I´ll add a few pictures of the aft command post.
Bye now!  :police:
pugwash
« Reply #5 on: November 11, 2010, 03:21:01 am »
Bernd a very impressive  start there is so much detail you would think you were working in 1/48 or bigger.
Geoff
Bernd
« Reply #6 on: November 11, 2010, 11:28:17 am »
Geoff
Thanks!  :-)
1:50th scale would be great ..... but my ship yard is too small ...  ok2
Bernd
« Reply #7 on: November 14, 2010, 10:49:31 am »
a jump in the timeline... last night´s work on my hull:
Besides drawing PE-parts I did some basic work on the reconstruction of the forward log ("speed measuring installation") on my Bismarck.
Here is what I researched so far:
- the device worked on the principle of dynamic pressure
- it was retractable (approx. 1.000 mm)
Bye,
Bernd.
Bernd
« Reply #8 on: December 05, 2010, 06:46:47 pm »
added the cooling water outlets in the hull bottom.
Bye!
Bernd
« Reply #9 on: December 05, 2010, 06:48:17 pm »
More pics of the sea boxes.
Bernd
« Reply #10 on: December 05, 2010, 06:50:11 pm »
More hull details.
Have a nice sunday evening!
Bye!
Norberto
« Reply #11 on: December 06, 2010, 12:54:32 pm »
Bernd your model hull is simply fantastic in model form and dedication :-)) :-)) :-))
Bernd
« Reply #12 on: December 25, 2010, 09:50:29 am »
I glued the seaboxes (cooling water outlet) of all 3 turbines into the hull bottom. Some finetuning is still necessary. The grills will be PE parts.
Merry Christmas!
Bernd
« Reply #13 on: January 08, 2011, 02:01:34 pm »
a short sequence of pictures showing a few steps of adding a seachest to the hull:
Pic 1: Determining the location of the seachest using frame numbers and waterlines.
Pic 2: Adding the opening for the seachest.
Pic 3: Fitting the seachest into the hull. Be sure to adjust the seachest to conform the bilge.
Bye now,
Bernd.
Bernd
« Reply #14 on: January 08, 2011, 02:02:23 pm »
Bye now,
Bernd.
Bernd
« Reply #15 on: April 17, 2011, 06:00:24 pm »
Added the cooling water inlet of the center turbine ...
Bernd
« Reply #16 on: April 17, 2011, 06:01:59 pm »
Added the auxillary cooling water inlet to the hull ...
Bye!  :-)
Bernd
« Reply #17 on: June 08, 2011, 11:15:40 am »
I started to add the starboard seabox of the cooling water inlet for the turbine and the bilge keel to my hull.
Pictures show a first dry fitting of all parts.
Hope you like it,
Bernd.
Bernd
« Reply #18 on: June 12, 2011, 03:20:59 pm »
I fixed the bilge keel to the hull with five M2-screws and epoxy. Puttied and sanded it once.
Now it´s time for a barbeque ....  %%
Bye!
dondecap
« Reply #19 on: July 23, 2011, 10:57:13 am »
hi mate.
that is indeed some superb work there,
it will be an exelant model at this rate.
regards
don
Bernd
« Reply #20 on: July 24, 2011, 07:42:57 pm »
Hi Don,
thanks for your kind words!
What´s going on on your yard, please?
Bye,
Bernd.
dondecap
« Reply #21 on: September 16, 2011, 09:11:02 pm »
hi mate,
just sorting out the plans now for a naval rescue tug .Storm king....
be about 3ft....when I can finally decide on the scale...:)
here is a 'glossy pic ' from a kit as referance.
just to keep me occupied over the winter....hahaha
regards
don
Bernd
« Reply #22 on: September 17, 2011, 02:36:32 pm »
nice subject ... will it be 1/48th scale?
Bye!
dondecap
« Reply #23 on: September 17, 2011, 03:47:18 pm »
hi mate
 looking at more like 1/4":1ft ish
but I have a set of plans for 3ft or so and scaled a set while I was waiting for those that came out at 4ft  or so.
 a aquandry now ....do I realy want a model at 4th.....transport etc..........
I have a 12 volt gell cell I was going to use so that may decide .....I will have to see if it will fit in the 3ft plans :)
that would be a lot easier......and bigger would not help really as there is not much fine detail like in the big warships.
your's is more like an engineering feat :) :) :)
enjoy
regards
don
Bernd
« Reply #24 on: November 16, 2011, 11:20:22 am »
sorry for the delay! 4 ft will be hard to handle alone, even 3ft is a challenge!
Bye now,
Bernd.
Page created in 0.093 seconds with 19 queries.
