Author Topic: 2.4 in Submarines  (Read 4661 times)
Nick
2.4 in Submarines
« on: October 31, 2010, 02:52:50 pm »
Im not sure if anyone has covered this topic before  but is it OK to put a 2.4 system in a Submarine please?
dodgy geezer
Re: 2.4 in Submarines
« Reply #1 on: October 31, 2010, 02:59:38 pm »
I'm not a submariner, but I understand that 2.4Ghz radiation will not go through water. So use it if your sub is a surface runner only...
wideawake
« Reply #2 on: October 31, 2010, 03:06:58 pm »
Yup a while ago I did some tests with a test rig submerged in a water butt and found that I lost control with the TX 4 feet from the RX and the test rig under 12 inches of water.
HTH
Guy
Nick
« Reply #3 on: October 31, 2010, 03:24:32 pm »
Thanks for that chaps. Oh dear, thats a pity  :(( :((
wideawake
« Reply #4 on: October 31, 2010, 03:28:24 pm »
Sure is.   On the other hand how would today's (non)cooks cope without microwave ovens?   {:-{
Guy
snowwolflair
« Reply #5 on: October 31, 2010, 04:06:41 pm »
2.4Ghz is the highest absorption fequency of water. So any signal just heats the water!
In practice a body of water such as a lake will shorten range for above water use, but not to an extent boat modellers will notice, however best to avoid flying over water.
nemesis
« Reply #6 on: October 31, 2010, 04:37:57 pm »
Hello, if you can get yourself a 27meg set, I had control down to 6ft standing directly above the sub, the depth deminished the further away the boat was.   Nemesis
dodgy geezer
« Reply #7 on: October 31, 2010, 05:48:19 pm »
The lower the frequency, the better the water penetration. Full size subs use Very Low Frequency (about 10kz) to penetrate about 100 ft of water at thousand-mile ranges. Trouble is you get very low data rates at these frequencies, and the aerials have to be tens of miles long...
Sub driver
« Reply #8 on: October 31, 2010, 08:17:32 pm »
40 meg is more than adequate for sub use. also beware of sailing in salt water. signal wont penetrate .
funtimefrankie
« Reply #9 on: November 01, 2010, 07:05:41 pm »
Is there any difference between receivers..(range wise)..ie the cheap Cirrus against a pucka Futaba.
Is it necessary to have the aerial outside the hull
Subculture
    • Dive-in to Model submarines
« Reply #10 on: November 01, 2010, 08:14:47 pm »
Dual conversion receivers give better reception.
