Author Topic: Advise on Brushless Electric Setup please.  (Read 2710 times)
Bugsy
« on: November 16, 2010, 02:03:43 pm »
As someone who has only ever sailed RC yachts I have very little knowledge on electrics. (as in nil) %)
I am scratch-building a 39" semi-scale model of a French Customs vessel with a hull very similar to a Perkasa.
I am aiming for scale speed (plus a bit) and planning to power it with two brushless outrunners through a single ESC.
Spec is as follows,
Two Keda outrunners 2837/18 with 830kv
Seaking 60A forward and reverse ESC
M4 shafts driving 40mm brass props
On a 7.2v NimH battery that theoretically gives me 5976 rpm - is that enough as a starting point ?
8.4 = 6972
9.6 = 7968
12  = 9960
The ESC is fan-cooled by a 5v, 7.2v max fan. If I go bigger than 7.2v I will need to separate the fan power supply to a separate 6v battery and it would seem logical, if I do this, to disarm the BEC and use a separate 6v battery to power both the receiver and the fan unit.
Is that sensible ?
Its mainly that I have to buy the batteries and would like to end up correct first time.
Thanks for any advice you can give.
Gary.
dodgy geezer
Re: Advise on Brushless Electric Setup please.
« Reply #1 on: January 07, 2012, 12:28:21 am »
The first point to make is that you cannot power multiple brushless motors through a single (brushless) esc. Each motor MUST have its own esc.
The reason is that for a brushless motor the esc provides the switching between the coils at the correct time to make the motor turn. It is an integral part of the motor, unlike a brushed motor where the commutator provides this timing. Without its ESC a brushless motor will not operate.
If you connect two motors to one esc, each motor will have slightly different timings and need slightly different signals - but it won't get them from a single esc. What would probably happen is that one (or both) motors would not turn, and they might burn out.
dodgy geezer
« Reply #2 on: January 07, 2012, 12:36:54 am »
I'm a little confused by your 'SeaKing' spec.  This one: http://www.giantcod.co.uk/hobbywing-seaking-reverse-program-brushless-p-403647.html
shows it as watercooled (and with a BEC capable of 24v). Is your version intended for a car?
Subculture
    • Dive-in to Model submarines
« Reply #3 on: January 07, 2012, 11:04:00 am »
Assuming the batteries are up to it, that combo should be good for about 7-8 knots, assuming 1.4 pitch props.
