Progress report: I've started building the Marie Jeanne. Planking was, er, OK; the round-out (correct term?) at the counter wasn't too severe, and after use of steaming and hot-water-soaking and careful bending, I managed to plank without breaking any! Attached photo shows the end result, ready for final sand and paint: I'm hoping to leave the planks' texture slightly visible through the paint, as working boats usually were in the original; the basic shape is smooth, but close inspection will show a couple of dents in the curves, which I am claiming are the result of a hard working life faithfully modelled......
For a beginner, the kit is accessible; it needs some critical thought before actually gluing some bits, and there are errors. The deck gratings are shown on Billings' photo as coming over the rear deckhouse, which has a sliding hatch on top: the gratings aren't high enough to clear the hatch, and even if they were, they'd block the hatch! I've shortened them to stop in front of the hatch. Also, it would be easier to drill the hole for the rudder post, through the keel, before decking and planking, for accuracy and ease of access.
Some bits are very delicate, and need very careful cutting/sanding/attaching, but that's probably normal, just news to me!
Instructions are inadequate for beginners/advanced beginners: there are reasonable plans, but words are limited to "Affix the other parts as shown in the drawing", and the drawings aren't clear enough for that, and there are inadequate photos. The photos on the box are clear, but don't match the parts in the box, and they're only of the starboard side - there is nothing of the port side, so my anchor fairlead is the result of educated guesswork. Also, the bowsprit and stern gaff (I think - the fixed horizontal bottom spar) are shown on the box photo with black straps to hold them down, but no parts, and the stern is shown in the diagrams with a 1mm brass wire hold-down!
Some parts are short: for example there isn't enough 1mm brass wire, but I've got some copper wire; some wood is insufficient but easily supplemented.
Conclusion: generally good kit of parts, but limited instructions, but application of common sense (and frequent reading of the Forum!) should see even a beginner through the hull. I am now to paint the hull according to Billings, and then it's masts and rigging.
I'm hoping to attach a photo of the boat before painting, here goes.
