Author Topic: Boiler material question  (Read 3967 times)
Kmot
« on: November 19, 2010, 05:01:34 am »
For anyone who knows:
When constructing a copper boiler, is it recommended to use the same thickness material for the end caps as the thickness of the boiler body?
Or is it a non critical issue?
I have 3" diameter Type L copper pipe which is .090" nominal thickness. I can get copper sheet in 14 gauge at .095" or 16 gauge at .065". The thicker the copper the harder to work it into some domed caps. I was hoping I could just use the 16 gauge for the end caps.
Thanks!
sunworksco
Re: Boiler material question
« Reply #1 on: November 19, 2010, 05:24:22 am »
As a person working in boilers for years, I myself would use the same thickness bulkheads as the copper tube.
You can always machine some mandrels and heat the thicker copper sheet, then compress the mandrels tight in a hydraulic press, made from an inexpensive jack.
Giovanni
Kmot
« Reply #2 on: November 19, 2010, 06:36:57 am »
Thanks for the advice John. :)
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #3 on: November 19, 2010, 07:32:22 am »
If you can't find the same thickness then dish the ends outwards which is the strongest form of boiler end caps, and stay it with a decent size (at least 5/32") bronze stay.
Greg
« Reply #4 on: November 19, 2010, 12:18:20 pm »
Don't go searching too hard Kmot, you've allready got some material the same thickness as the tube? It's called "The Tube" (Slit and flatten a piece). On the "Other" forum in the books section, there's a freebie download of Hariss's Bible, that's the one everyone should be following for the pressure calcs.
  Regards  Ian.
  Oooooooooooops, nearly forgot, ANNEAL regularly, saves tears (The crying ones)
gamma
« Reply #5 on: November 19, 2010, 04:49:34 pm »
Hi kmot...nice to see you here too   :-))
Sergio
Kmot
« Reply #6 on: November 19, 2010, 05:14:26 pm »
Thank you all,  for the replies. Re: cutting off a piece of tube and slitting, etc. Nope, sorry Ian, that would end up making a very short boiler!  {-)
Anyway, per most advice I have placed an order for a piece of .093" sheet. (I was wrong about it being .095).
I have Stan Bray's book and I intended to make a domed hardwood form, and pound the annealed piece of sheet over it. Re-annealing as I work it. However, I very much like the idea of sunworksco about making a mandrel and using a hydraulic bottle jack. I will have to think about that some more.
Hi Sergio!  ok2
