Author Topic: esc problem  (Read 1915 times)
hover tim
esc problem
« on: November 19, 2010, 08:40:28 pm »
hello all
i tried a brushless esc and motor combo today and for some reson the motor tries to start goes a bit then stops and does this again and again and again it and afterreapting this cycle it starts up and kicks into life why does it do this
triumphjon
Re: esc problem
« Reply #1 on: November 19, 2010, 08:42:57 pm »
ive had a brushless motor , and before use the esc needed programing ! have you set yours up ?
hover tim
Re: esc problem
« Reply #2 on: November 19, 2010, 09:24:19 pm »
aparently its a plug and play one
TomTheKraut
Re: esc problem
« Reply #3 on: November 20, 2010, 04:29:18 pm »
Hello Team,
... "plug and pray", one might think.
But on a more serious attempt: if we are to give really helpful advice, we should have the following data:
  • Type of the brushless motor (inrunner / outrunner) plus essential data (voltage range, rpm per Volt, max Amps under load)
  • Data of the ESC (voltage range, max. continuous current in Amps)
  • Type of boat you want to propel with the motor/esc combo (Tug or raceboat? size?)
  • Size and type of the prop you are using
  • Which voltage are you feeding through the drivetrain
A link to the vendor site of the motor/esc-combo might be helpful as well.
The very brief description you give in your initial post leads me to suspect the motor being loaded too high, i.e. the boat and/or the prop being too big or the wrong type for the motor, thus pulling enough current to run the ESC into the safety-cut-off.
But a more educated guess can only be given if and when we have answers to the above questions.
Page created in 0.123 seconds with 20 queries.
