Author Topic: Converting my Steam Tug Cruiser to Brushless electric....success!!  (Read 3052 times)
muduck
For various reasons I wanted to convert her,all 36llb,(lots of Ballast) to electric & I wanted to try brushless.
Maiden voyage the other day & it's all I could hope for.
I have a 4 blade 70mm prop.
Motor:Turborix 850rpm/v D3648 RC 500 Helicopter Outrunner Brushless Motor
Escape: Hobbywing SEAKING 60A watercooled.
I run the whole lot on 6V.lead acid
Am currently waiting on a sound card from Model Solutions of Canada to give the "bling"
With the above sys I have stacks of power at low scale speeds.Of course, during trials I had to give her a "burst".....ever seen a tug  leap up on a plane %%
well worth the effort.
muduck
Re: Converting my Steam Tug Cruiser to Brushless electric....success!!
« Reply #1 on: December 18, 2010, 06:58:18 AM »
Just added a couple of vids on U tube..one chugging nicely, & one showing a turn of speed.
http://www.youtube.com/watch?v=ezwJLSQZU2Q
http://www.youtube.com/watch?v=bXc2FWSTJBA
HS93 (RIP)
  • I cannot spell , tough
« Reply #2 on: December 18, 2010, 07:01:19 AM »
that's going well, did you sell the steam plant I think I saw it up for sail somwhere ?
peter
muduck
« Reply #3 on: December 18, 2010, 10:59:16 AM »
Yes Peter...went back to the Northern Hemisphere..Denmark
phillnjack
« Reply #4 on: January 28, 2011, 08:35:56 PM »
ive just looked at a site that seels these motors.
it says 11.4 volts   and not to run for more than 5 mins then 2 mins off  !!!!
is it realy ok to run this on just 6 volts ? and for more than the recommended 5 mins ?
im asking as i like the look of these brushless motors
phill :-)
nick_75au
« Reply #5 on: January 28, 2011, 11:35:55 PM »
Phill do you have a Link?
Running a motor at half its voltage reduces the power considerably, so the heat the motor has to dissipate is well within its limits. In a Heli application high power in low weight is required so no weight can be used for heat-sink and the cooling is non existent from prop wash therefore the duty cycle is reduced.
Nick
phillnjack
« Reply #6 on: January 29, 2011, 01:58:17 AM »
here is the link to what ive read.
http://www.r2hobbies.com/eng/proddetail.php?prod=rcps81521_850
hope i didnt read it wrong
phill
nick_75au
« Reply #7 on: January 29, 2011, 05:16:33 AM »
It looks to me as if the duty cycle was just for reliability testing, Keep it under 1000 Watts and that should be a continuous (off a battery/limited supply) rating
1000 watts at 14.4 volts is 70 amps, we are not going to reach that in a scale boat ok2
This motor would be wasted on anything less than a 60 mm prop in a tug.
Nick
muduck
« Reply #8 on: January 29, 2011, 10:20:38 PM »
I have a water cooled controller, I run a small electric motor to drive it...The setup  I use has a 70mm prop, allup weight is about 35pounds..it's a 6V system, & has LOTS of Grunt..as a Tug should %%
phillnjack
« Reply #9 on: January 30, 2011, 04:49:47 PM »
Sounds like a real good set up
does running on 6 volts seem ok with the motor ?
would it not be better on 12 volt running finer pitch props for even more torque ?
i am asking has im not too up on the electric boats/tugs
phill
muduck
« Reply #10 on: February 01, 2011, 10:22:14 PM »
I'm running on6V for an hour at a time,motor purrs.....
