Author Topic: Plastic filler  (Read 3738 times)
Ben Tickle
Plastic filler
« on: December 01, 2010, 03:57:13 pm »
Does anyone know what plastic filler is? Is it a special type of filler that is used with model making?
ben
Big Ada
Re: Plastic filler
« Reply #1 on: December 01, 2010, 04:37:00 pm »
What are you going to use it on ?.
Ben Tickle
Re: Plastic filler
« Reply #2 on: December 01, 2010, 05:10:54 pm »
I am going to use this on ABS or styrene plastic.
Ben
tobyker
Re: Plastic filler
« Reply #3 on: December 01, 2010, 09:23:50 pm »
I use some stuff called "Squadron White putty" - it seems to stick to most anything.
Sub driver
Re: Plastic filler
« Reply #4 on: December 01, 2010, 10:34:00 pm »
humbrol do a tube called plastic filler specifically for plastics. it fills easily and dries quick and is easily sanded without making a mess of the surounding plastic. it is used by the plastic modellers and is redily available.  regards sub.
Re: Plastic filler
« Reply #5 on: December 02, 2010, 08:04:07 am »
Yep seconded and I also use revell plasto
Ben Tickle
Re: Plastic filler
« Reply #6 on: December 02, 2010, 09:48:31 am »
Thanks for the advice. Where do i get this from.
Ben
BigA
Re: Plastic filler
« Reply #7 on: December 02, 2010, 11:53:00 am »
Milliput is also good, as is Davids Isopon P38 - both are two-pack components, the latter is quick to set (10min at room temperature).
Re: Plastic filler
« Reply #8 on: December 02, 2010, 12:43:48 pm »
Ben
Cornwall model boats or ebay are good starting points
BigA
Re: Plastic filler
« Reply #9 on: December 02, 2010, 01:25:08 pm »
Isopon P38 from Halfords.
Re: Plastic filler
« Reply #10 on: December 02, 2010, 02:18:00 pm »
Re: Plastic filler
« Reply #11 on: December 02, 2010, 02:19:26 pm »
You're back then?
Big Ada
Re: Plastic filler
« Reply #12 on: December 02, 2010, 04:39:36 pm »
Make your own by putting small bits of strene in a bottle a pouring some styrene solvent over it and leave over night, the bits disolve and make a thick filler, adjust with more or less bits or solvent.
Seeeemple.
Len.
Re: Plastic filler
« Reply #13 on: December 02, 2010, 06:51:55 pm »
And "thick glue" for ABS is ABS shavings dissolved in MEK ( Ketone). A good one for styrene was Trichloretylene used both for capilliary action as a thin glue and with bits added as Len says, for a thicker one.
  Regards  Ian
tobyker
Re: Plastic filler
« Reply #14 on: December 02, 2010, 08:55:35 pm »
Only problem with making your own with styrene shavings is that you can melt the surrounding styrene unless you get the consistency 100% right (how do I know that?!). Safer (IMHO) to use filler - I get Squadron from my LMS, Paisley Models.
Page created in 0.092 seconds with 21 queries.
