Author Topic: sealing a propshaft  (Read 5833 times)
returnee
sealing a propshaft
« on: December 14, 2010, 12:07:59 pm »
Can anyone tell me how to stop water from coming up the propshafts on the yorkshireman
BigA
Re: sealing a propshaft
« Reply #1 on: December 14, 2010, 12:13:15 pm »
Keep it full of grease or oil - re-oil regularly - oil, being less viscous, will seep out eventually.
Make sure the bearing at the wet end is secure. Perhaps consider using a PTFE (flat) washer between the prop and beaing/shaft end?
A.
« Reply #2 on: December 14, 2010, 12:49:21 pm »
Check that there is as little play as possible between the prop tube end and the washer and the prop nut.
 If it's an old (aged) model, it could be that the bearings are worn....
nhp651
« Reply #3 on: December 14, 2010, 01:08:28 pm »
Just doing mine on my Big Clyde class lifeboat..........I use Vaseline mixed with carbon powder that I bought at an engineers years ago............gives great lubrication and water tightness......but even so I still get slight weepage if the boat is in the water for longer than a couple of hours.
neil
roycv
« Reply #4 on: December 14, 2010, 04:05:20 pm »
Hi all, vaseline can get very viscous, especially when cold, but if you use the following mixture it works well.
1 part Vaseline, 1 part WD30,1 part 3 in 1 oil.
It mixes into a less viscous version of vaseline.  Stays where it is put, works well when it is cold.
good luck
Roy
davidm1945
« Reply #5 on: December 14, 2010, 05:14:47 pm »
WD30?....Is that WD40's little brother?   %)
Dave.
roycv
« Reply #6 on: December 14, 2010, 05:29:53 pm »
Hi I think it must be so if you can't get WD30 then WD 40 will have to do!
Roy
returnee
« Reply #7 on: December 14, 2010, 07:00:55 pm »
Thanks for all the info , will give the 3 in 1 a try
class37
« Reply #8 on: December 14, 2010, 07:25:36 pm »
I use copper slip, tin from halfords will last a couple of lifetimes.
Take propshaft out and half pack tube from propeller end with copper slip, then slide the shaft back in, turning it as it goes in, keeping some pressure on the open end which forces the copper slip down the side of the shaft between it and the tube wall, then allow excess to push out as shaft goes right through tube. wipe off all excess copper slip and fit washers and nuts.
Haven't found that water gets into/ mixes with the copper slip, and haven't noticed any evidence of the copper slip leaking out of the tube to contaminate the water.
Shaft is free turning, so there doesn't seem to be any friction.
cheers
alan
Peter Fitness
« Reply #9 on: December 14, 2010, 08:49:55 pm »
The question of oil versus grease has been debated on many occasions. Those in favour of oil point to the fact that oil offers less resistance than grease (or grease like substances) which is quite true but, for practical purposes the difference is negligible. It may be a problem in high speed craft where every RPM is vital, but for most models the extra battery drain would be minimal. I have always used grease of the outboard motor variety which, to all intents and purposes, is waterproof, and have never had a problem with water getting into a hull via the prop tube.
However, in my opinion there is no "right" or "wrong" method, it's whatever works for you.
Peter.
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #10 on: December 14, 2010, 09:13:53 pm »
I wonder if anyone with surface skimmers has taked a leaf out of what model submariners do. No leaks, no real maintanence.
http://www.engel-modellbau.eu/catalog/product_info.php?cPath=92_93&products_id=539
RaaArtyGunner
« Reply #11 on: December 15, 2010, 12:25:55 am »
Makes interesting commentary and point regarding wear of brass v stainless
Mankster
  • Wheelerdealer
« Reply #12 on: December 15, 2010, 12:27:56 pm »
Yes I dont think anyone uses brass shafts anymore for that very reason (and they bend easily too)
cosmic
« Reply #13 on: December 15, 2010, 12:36:33 pm »
Dow Corning High Vacuum Silicone grease. Cannot wash out with water.
returnee
« Reply #14 on: December 15, 2010, 02:39:42 pm »
Thanks Cosmic. you fellows have given me a grest many ideas.
RaaArtyGunner
« Reply #15 on: December 15, 2010, 10:47:28 pm »
Good to know  :-)) :-))
Peter Fitness
« Reply #16 on: December 16, 2010, 04:53:13 am »
We have one member in our club who always uses brass shafts and swears by them. Others tend to swear at them. I much prefer stainless steel.
Peter.
davidm1945
« Reply #17 on: December 28, 2010, 05:52:26 pm »
A.
Hi, BigA (or anybody else!),
    Any ideas where I can get M4 PTFE washers in small quantities?
Dave.
cosmic
« Reply #18 on: December 28, 2010, 06:38:09 pm »
Dave.
You might try bestrcdeals.com. I know that they carry insulating shim washers in metric sizes. I think they are made by Integy.
Tom Herman
« Reply #19 on: December 28, 2010, 07:52:22 pm »
Hi there,
I have a twin screw model tug.....the shaft ends have been made to accommodate suitable "O" rings.   It will keep the lubricant in and the water out!
Tom
Page created in 0.015 seconds with 21 queries.
