Author Topic: Stripping the paint from a Victoria hull  (Read 4138 times)
« on: December 17, 2010, 03:45:15 pm »
I've got hold of a wreck of a Victoria with the idea of making it better than new.
The hull has been painted a couple of times very badly.
I need to strip the hull and deck back to the original plastic.
Modelstrip sounds good but having to fit the pasted hull into a bag overnight is a bit awkward.
Do any of the other suggestions i.e. Dot3 brake fluid / Oven Cleaners work on the Vic hull?
Any ideas Mayhemers?
Re: Stripping the paint from a Victoria hull
« Reply #1 on: December 17, 2010, 04:00:53 pm »
Is the hull plastic or GRP?
« Reply #2 on: December 17, 2010, 04:19:38 pm »
It's Plastic
« Reply #3 on: December 17, 2010, 04:37:47 pm »
Ned,
If it is plastic then the paint can only lay on top of the plastic so something like Mr Muscle should be able to soften/remove the paint without damaging or being absorbed into the hull.
« Reply #4 on: December 17, 2010, 05:28:26 pm »
Should have qualified plastic as ABS plastic
Electronics, Timber,West and SPS epoxy systems
No probs but 'plastic' toys  Help!
chingdevil
« Reply #5 on: December 17, 2010, 05:28:36 pm »
Fairy Power Spray is fairly good for that.
Brian
triumphjon
« Reply #6 on: December 17, 2010, 09:34:11 pm »
go for the fairy power spray , its not cheap but ive also tried some and can agree that it works very well ! jon
« Reply #7 on: December 18, 2010, 07:41:56 am »
Fairy Power Spray it is then.
Not Cheap?
I'll just drop it in the trolley next time SWIMBO shops :-)) :-)) :-))
Thanks for the replies everyone
YoursAye
HS93 (RIP)
  • I cannot spell , tough
« Reply #8 on: December 18, 2010, 07:54:37 am »
I had some metal parts that had been painted with humbrol and some had been sprayed primed first then good gloss I was de greasing them before I set about attacking them with a 3m mop left them a couple of hours came back turned hot tap on to wash it off and the paint came off like a skin, I had spent two weeks doing a chassis that was a pig to get at some parts and this way it just fell off . if it is metal quickly burnish surface and get a quick coat of etch primer on or it will rust , etch primer is not good on plastic by the way.
peter
« Reply #9 on: January 04, 2011, 10:01:38 am »
I can endorse Brian & Jon
Fairy Power Spray does the job.
Plus on roll back at Asda £2
Tesco £3.50
No prizes for guessing where I bought mine   :-)) :-)) :-))
Yours aye
Page created in 0.043 seconds with 17 queries.
