Author Topic: How well do servos work upside down?  (Read 2574 times)
AndrewB
« on: December 20, 2010, 10:13:55 am »
I am thinking of mounting my rudder servo upside down directly on to the center rudder horn (three rudders) going off the horn to the outer rudders , See image
What do you guys think?  Will it work
Andrew
Subculture
    • Dive-in to Model submarines
Re: How well do servos work upside down?
« Reply #1 on: December 20, 2010, 10:38:41 am »
Servos work well in any orientation.
« Reply #2 on: December 20, 2010, 10:39:26 am »
Servos dont care which way they face.  The limit is being able to get at any linkages and fixings, because if you cant get at them, they will fail.
A while back, someone fixed a servo horn to the boats transom with the rudder fixed to the servo to make it look like an outboard.  That worked, as well.
« Reply #3 on: December 20, 2010, 10:54:41 am »
Hi Andrew
Yes is the simple answer - a servo will normally work in any position ,on it’s side, upside down, and if you have a look at the RTTL 2751 built - I mounted the servo upside down on this model to save space and if you look at the 63 foot whale back build - you can see how I overcame the problem of connecting 3 rudders together.
 http://www.modelboatmayhem.co.uk/forum/index.php?topic=20758.50   (  RTTL )
Aye
John E
Aka
bluebird
AndrewB
« Reply #4 on: December 20, 2010, 11:04:40 am »
Thanks for that guys, Ill give it ago  :-)
Page created in 0.163 seconds with 22 queries.
