PAINTING SAFETY
This issue of our discussion is about painting safety. Its something talked about among modelers from time to time, but not often practiced. We tend to get into the thrill of the build and tend to overlook the hazards we are dealing with because “we are only using a little bit” “for a short time”. Quantity and length of exposure certainly are defining factors in what happens to our bodies when we uptake a chemical hazard. However, the type of hazard is very much an important factor too. Here we will discuss some of those hazards and how we can control them and reduce the risk involved.
We use a wide variety of different chemicals in our desire to create the latest and greatest. I’m no different than the rest. We get into lacquers, cyano acrelates, enamels, fumes created from such things as soldering and from resins when building hulls to name a few. In much of this work our exposure time is short, however, depending on how many models we build the effects can build over time.
Lacquer paints are probably among the worst we deal with on a regular basis. This is because they contain VOC’s (volatile organic compounds). These compounds make up such chemical compositions as aliphatic hydrocarbons, ethyl acetate, glycol ethers, and acetone. Granted many of us have switched over to water base paints, however, I’m one of the hold outs because of the finish, cover ability and durability compared with other types of paints. With that in mind here is a write up of the effects of lacquer based paints from the Sherwin – Williams paint site:
Section 5 — Health Hazard Data
ROUTES OF EXPOSURE
Exposure may be by INHALATION and/or SKIN or EYE contact, depending on conditions of use.
Alcohols and acetates can be absorbed through the skin. Follow recommendations for proper use,
ventilation, and personal protective equipment to minimize exposure.
ACUTE Health Hazards
EFFECTS OF OVEREXPOSURE
Irritation of eyes, skin and respiratory system. May cause nervous system depression.
Extreme overexposure may result in unconsciousness and possibly death.
Headache, dizziness, nausea, and loss of coordination are indications of excessive exposure to vapors or spray mists.
Redness and itching or burning sensation may indicate eye or excessive skin exposure.
MEDICAL CONDITIONS AGGRAVATED BY EXPOSURE
None generally recognized.
EMERGENCY AND FIRST AID PROCEDURES
If INHALED: If affected, remove from exposure. Restore breathing. Keep warm and quiet.
If on SKIN: Wash affected area thoroughly with soap and water.
Remove contaminated clothing and launder before re-use.
If in EYES: Flush eyes with large amounts of water for 15 minutes. Get medical attention.
If SWALLOWED: Urethane Retarder => Get medical attention.
Other Products => Never give anything by mouth to an unconscious person. DO NOT INDUCE VOMITING. Give conscious patient several
glasses of water. Seek medical attention.
CHRONIC Health Hazards
Carbon Black is classified by IARC as possibly carcinogenic to humans (group 2B) based on
How do we adequately protect ourselves from these hazards? Proper ventilation and wearing breathing protection is the best. What we don’t want to do is limit ourselves to a confined space where the toxins can accumulate while we breathe. Some of us spray outdoors with no other protection. A good start, but wearing some additional breathing protection would be a whole lot better.
What about spraying inside our shop? After all we can’t always wait until the next sunny day to unleash our artistic talents through an airbrush. I know of at least one chap told me he had a spray booth. When I looked at it I was shocked. He was spraying directly into an unventilated cardboard box. I reminded him about the hazards and how he was magnifying them through his painting method. He brushed it off as fine. A few years later he was pulling an oxygen bottle around; I don’t think he’s alive now. The word is be wise and be careful.
For many years I’ve used a ventilated paint booth that I built. I constructed it from plywood. I didn’t have any dimensions to go by, so used some test ideas to come up with what I have. I tried to keep the box as small as I could reasonably do and allow me comfortable access to the inside with some fairly large pieces. I went to my local hardware store and bought the biggest kitchen ceiling fan I could find, to shift the most amount of air. I also made sure it had a spark less (or brush less) motor drive. The sparkles or brush less motor is required due to the volatile nature of paint fumes. Lacquer and oil based paints being the worst. The sparking of the motor brushes, during operation, can cause the fumes to ignite rather violently when painting.
I have the fan in the top of the fume hood, more due to my circumstances. The fan could be mounted under the fume hood to produce a downdraft type of paint booth. The fan was exhausted to the outside of my workshop. When I had it assembled and tried it, I lit a candle and, with the fan running, held the candle in the box opening to see the draft effect. The candle flame was drawn into the box indicating the draft was working as desired. I have no way to measure the air movement by volume. However, I haven’t run into a circumstance of smelling paint outside the paint booth.
With this design I can put most of my modeling work inside the booth and spray with a reasonable expectation of the fumes exhausting to the outside of the workshop. I took advantage of the paint booth structure to add a paint rack on one side and put my moisture trap on the other along with an electric power bar.
There are many commercially made paint booths on the market that will do as advertised. If you wish to build one according to plan you can try these web sites:
http://modelpaint.tripod.com/booth2.htmhttp://pages.interlog.com/~ask/scale/tips/booth.htmMy paint booth. The fan is the grey portion on top. The stove piping vents the booth up a spare chimney in my house.
This picture shows the paint rack I made for one side of the booth. Keeps the most commonly used paints close to hand.
As an additional breathing protection, I recommend an air mask. One that you can change the filtering arrangements on is best. That way you install charcoal filters when spraying oils or organics and fiber glassing resins, and use a mechanical filter medium for those times you’re doing sanding on your hulls. Pick a design that covers your nose and mouth comfortably and allows you to interchange the filtering medium by unscrewing the cartridge for replacement.
Both the mask and hood should look after your breathing needs adequately. Don’t forget that VOC’s can be absorbed through the skin, so some sort of hand protection is advisable. This all sounds like a lot, but it will save you a lot of grief later in life.
