April 25, 2024, 12:15:36 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
steam boiler for stuart triple
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: steam boiler for stuart triple (Read 1735 times)
pip jones
Guest
on:
December 21, 2010, 02:04:59 pm »
can anyone tell me if there is a boiler made to suit the stuart triple. it must produce about 4lbs steam per hour at 150psi, and i am struggling to find something suitable. regards, pip jones.
Full Mayhemer
Offline
Wollongong Australia
Re: steam boiler for stuart triple
Reply #1 on:
December 21, 2010, 07:06:30 pm »
pip....talk with mailto:
mike@maccsteam.com
boilers....his largest boiler [6" horizontal] is listed as follows...I would suggest you simply confirm your intended engine as your specification requirement
[4lbs steam per hour]
is questionable .....Derek
______________________________________________________________________________________________________________________________________________________________________
Diameter 6 " (150mm)
OA Length (including burner) 11.5" (290mm)
Length of pressure vessel 7.5" (190mm)
Flue tube diameter 2 X 2" (50mm)
Number of cross tubes 10 in each flue
Number of longitudinal stays 9
Outer shell thickness 10G (3mm)
Approximate total capacity 2.5L
Maximum working pressure 80psi (5.5 bar)
Test pressure 160psi (11 bar)
Weight including burner 5.2kg
Burner (2) diameter 2 " (50mm).
Fuel Butane or butane/propane mix.
2 off 5/16"x32tpi bushes in backhead for water gauge. 1 1/4"x40tpi bush in backhead for pressure gauge.
1 off 5/16"x32tpi bush in boiler top for safety valve.
1 off 5/16"x32tpi bush in boiler top for steam outlet.
1 off 3/8"x32tpi bush in boiler top for steam manifold
1 off 5/16"x32tpi bush in boiler side for check valve
2 blind bushes tapped M6 are fitted in the bottom of the boiler to allow mounting in a suitable cradle.
Measured steam output 1600 cu ins/min (26219ml/min) at 50psi (65/35 mix)
Gas pipe diameter 1/8"
Steam Pipe Ouutlet 3/16"
Exhaust pipe diameter 1/4"
pip jones
Guest
Reply #2 on:
December 21, 2010, 11:17:05 pm »
thanks derek. the problem is i have been told that the triple will only run efficiently on 120-150psi, and the maccsteam boiler is only rated at 80psi. it will obviously run on this pressure, but not to its full potential. regards, pip
Full Mayhemer
Offline
Reply #3 on:
December 22, 2010, 05:03:01 am »
I understand all that pip....but thought Maccsteam may do HP specials .....Derek
pip jones
Guest
Reply #4 on:
December 22, 2010, 07:25:54 am »
i must admit i had not thought of that. thanks for the advice, and i will contact maccsteam today and see if they do a high pressure version. fingers crossed. regards, pip.
HS93 (RIP)
Full Mayhemer
Offline
I cannot spell , tough
Rainhill UK
Reply #5 on:
December 22, 2010, 07:41:54 am »
Also try they do boilers to order all types
http://www.cheddarvalleysteam.co.uk/
Tim was the boiler maker at Cheddar Models so will probably know what you need.
Peter
Full Mayhemer
Offline
North of Watford, South of Hadrians wall
Reply #6 on:
December 22, 2010, 07:50:23 am »
http://www.westernsteam.co.uk/
Quality speaks for itself.
Regards Ian.
What I said is not what you think you heard.
Full Mayhemer
Offline
Reply #7 on:
December 22, 2010, 08:05:33 am »
Thanks Circlip........I had the name
www.western
in my favourates listing but couldn't associate boilers
I think it is amazing when we have a female of the species as a qualified & certified boiler builder
.....Derek
Full Mayhemer
Offline
Reply #8 on:
December 22, 2010, 12:41:59 pm »
She is an ex Cheddar apprentice and is
Highly
regarded as one of the best Derek. One of hers is in the Philippines.
Regards Ian.
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
