Author Topic: TUG M.S.C ARCHER built in pictures  (Read 17080 times)
« on: December 21, 2010, 07:22:28 pm »
Here is a build which I did last year - never did a write up for it - so thought I would post this in pics - plans cames free with Model Boats magazine, a while ago - anyway here we go.
The power plant is a 555 motor on a 7.2 NiCad battery through an ACTion speed controller - a 10 amp one, driving a 4 blade 50 mm brass prop.
aye
john
Re: TUG M.S.C ARCHER built in pictures
« Reply #1 on: December 21, 2010, 07:25:14 pm »
more pics
« Reply #2 on: December 21, 2010, 07:27:30 pm »
« Reply #3 on: December 21, 2010, 07:30:21 pm »
« Reply #4 on: December 21, 2010, 07:33:09 pm »
« Reply #5 on: December 21, 2010, 07:35:56 pm »
« Reply #6 on: December 21, 2010, 07:39:42 pm »
« Reply #7 on: December 21, 2010, 07:42:31 pm »
« Reply #8 on: December 21, 2010, 07:44:21 pm »
« Reply #9 on: December 21, 2010, 07:47:36 pm »
« Reply #10 on: December 21, 2010, 07:50:39 pm »
« Reply #11 on: December 21, 2010, 07:54:37 pm »
THE END
aye
john E
john1951
« Reply #12 on: December 21, 2010, 09:08:03 pm »
Amazing watching this model come to life !
                  Wish I had the time and skill to do it !
tugnut
« Reply #13 on: December 21, 2010, 09:13:12 pm »
Well John that looks great,  nice to see your build many thanks for posting.
Best regards John B
dreadnought72
« Reply #14 on: December 21, 2010, 09:14:40 pm »
That's lovely - thanks for sharing it.
A picture says a thousand words, huh? There's a novel in the above!
Martin13
« Reply #15 on: December 21, 2010, 09:25:28 pm »
Hmmm........those RED and BLACK arrows look familiar %) ;) :-))
longshanks
« Reply #16 on: December 21, 2010, 09:56:11 pm »
Nice one !
Good to see you back   :-))
bosun
    • bosunsmodelboats.com
« Reply #17 on: December 21, 2010, 11:06:03 pm »
Hy John
Excellent build as always, you really know your stuff mate.
Bosun
PS, Happy Christmas and have a great New Year
octo
« Reply #18 on: December 22, 2010, 09:46:14 am »
Best adjective i can come up with is:- Marvellous!!!!
 Wishing You and yours Seasons greetings
   Tony
LarryW
« Reply #19 on: December 22, 2010, 10:14:51 am »
hi Larry w here a very nice build have plan on back burner , all ready built a john pollinger plan of john king ,went well ,
   nice to see photo step by step of build its a good help to use beginners .
    for info what are bulkhead and keel timbers and plank strips timber , allways looking for easy ways .....cheers Larry w :-))
« Reply #20 on: December 22, 2010, 10:32:45 am »
Thanks for sharing Intel........there are many educational snaps in the build that certainly will be of use to any POF builder be they young or old..... :embarrassed: experienced or new starter >>:-(
I particularly like the improvised method of lofting the height of the bulwarks & the water line on the vessel itself..........congratulations  :-)) ......... Derek
The long Build
« Reply #21 on: December 22, 2010, 01:41:05 pm »
Brilliant   :-)) :-))
Larry R.
tony52
« Reply #22 on: December 22, 2010, 01:57:54 pm »
A superb model.
Just one question - what timber did you use for the planking?
mike_victoriabc
« Reply #23 on: December 22, 2010, 03:13:04 pm »
Very nice!! We tend to steer towards the glass hulls but you show us how it can be done. I remember that small hand drill and fret saw from my father building sailboats in the 60's - I since jumped ahead to the scroll saw. Thanks for taling the time to take the photos and post them!
« Reply #24 on: December 22, 2010, 08:42:22 pm »
hi ya there one and all
thank you for the comments - to fill a few gaps in the build for those who dont know - the plan comes from Model Boats October 2008 issue - the only comment I can make about this plan and a couple of others which I have built from magazines - is that when they are drawn I would presume they are near enough correct - but when the printer gets their hands on the plans - it may be they are distorted a bit whilst being re-sized to fit the magazine pages etc.   I may be wrong but I am sure that is one of the problems.    If you have a look at one of the pics - you will see me pointing to a frame which I had to build up; as it was too low - when I was fairing the rest of the frames in.
Materials:  The main frames/shadows/sections whatever you may wish to call them are made up of quarter birch ply from Jotika.  This may be expensive ply, but, the plus points are that this is ‘true’ 5 ply – meaning there are 5 veneers in its makeup.  Also, there are no voids in between the inner veneers which can be found on ‘cheaper’ ply woods – by voids I refer to gaps between the inner layers.
The keel is made up of ¼ inch birch ply.
The planking material is Obechi 1.5 thick x 8mm wide.
If you look on the Cervia build on this forum; (its in the master build class section) the build sequence of this model build follows the Cervia build – in such a way there is a glassfibre/tissue applied to the exterior of the hull.  The main difference between the two builds is that the Cervia build used a gear box which was belt driven by MFA – in the drive line (Olympus) and I was asked after the build what would be a suitable motor to direct drive the Cervia tug and on this build I deliberately located a suitable motor from ACTion Electronics which turns out to be a 12 volt 555 motor.   When under load driving the 4 blade 50 mm prop she is only drawing 2 amps.
The other part I deliberately changed on this build was the access to the rudder servo.  Again, in the Cervia build, if anything goes wrong with the rudder servo/linkage you have to do major surgery to reach the affected parts.  But, as you can see on this build I moved the rudder servo forward to make it more accessible when removing the main super structure.   If things go wrong with the main tiller connections on the rudder; there is still a little bit of surgery to be done on the deck but can easily be camouflaged by the grating.   Hope this is of some help.
Aye
John e
