Author Topic: 27mhz RX Antenna wire length  (Read 3314 times)
« on: December 28, 2010, 02:23:22 pm »
I have one and the wire has broken off as it leaves the casing so it needs to be replaced.  I know the wire length is quite important so what should it be?
Its the only 27 on I have so I dont have anything as a reference (all my others are 40's
Re: 27mhz RX Antenna wire length
« Reply #1 on: December 28, 2010, 02:29:50 pm »
The length is not too critical for boating use. Somewhere between 27 to 30 inches should be fine.
« Reply #2 on: December 28, 2010, 03:38:43 pm »
Cool
Cheers for that speedy reply!
Mince pie and a single malt for that man!
Happy New year
phillnjack
« Reply #3 on: January 01, 2011, 01:37:04 pm »
If you use an ariel of the piano wire type with a spring loaded bottom, its best to get a bit of cotton and
use it to measure round the coils to see what length is taken up by the coil.
Best to be on the safe side
phill :-))
