Author Topic: Propeller  (Read 9185 times)
Ben Tickle
Propeller
« on: January 08, 2011, 06:15:40 pm »
Just wondering if a boat only has one prop, how do you distinguish whether it is right hand threaded or left?
Ben :-))
john s 2
Re: Propeller
« Reply #1 on: January 08, 2011, 06:22:03 pm »
Ben. The propellers that i use M4 are only clockwize threaded Both lh and rh have the same  thread.Use of a locknut and possibly a
thread lock compound will keep prop secure.Regards John
Ben Tickle
Re: Propeller
« Reply #2 on: January 08, 2011, 06:30:31 pm »
All of my props spin to the left so which thread would i need?
Ben :-))
john s 2
Re: Propeller
« Reply #3 on: January 08, 2011, 06:42:45 pm »
Hello again Ben.The actual thread inside a prop can be of diffrent sizes. Nowadays the popular size is 4mm.Also 2mm and 5mm for
bigger props.Before this there was various Imperial sizes such as 4ba etc. If you have a fastener shop near you you could pop in
Im sure that they could id for you.It is possible to count threads an measure diameter.Possibly there is a model shop near you who
could id your thread? John.
Ben Tickle
Re: Propeller
« Reply #4 on: January 08, 2011, 07:33:46 pm »
I have got a standard m4 prop shaft and i am wanting a suitable prop for it, could anyone please help?
Ben
hollowhornbear
Re: Propeller
« Reply #5 on: January 08, 2011, 08:09:50 pm »
then that's what you want an M4 prop. Diameter/ rotation direction have no relevence.
nick_75au
Re: Propeller
« Reply #6 on: January 08, 2011, 08:15:37 pm »
Ben
Asking that is like going to a lingerie shop to buy a bra for a girlfrend and not knowing her cup size ;D  or what colour she likes.
Raboesch are all M4 with the exception of the largest 75 mm? and up props, most of the Graupner props are also M4
Nick
Ben Tickle
Re: Propeller
« Reply #7 on: January 08, 2011, 08:20:52 pm »
Thats what is confusing me, the rh and lh bit, its m4 and the prop needs to be 30mm, so i take it tht it dont matter what thread it is?
Ben
nick_75au
Re: Propeller
« Reply #8 on: January 08, 2011, 08:42:53 pm »
M4 thread is always a RH thread, but the props can be LH or RH Pitch, single screw boat wont matter which direction, the electric motor "may" prefer a direction for forward running.
Nick
gribeauval
Re: Propeller
« Reply #9 on: January 08, 2011, 08:49:02 pm »
Ben
Ben forget about left and right hand threads, that's what is confusing you. Nearly all propshafts are standard M4 or M5 threads. What you need to know is in what direction is the prop spinning.
In the UK props are referred to as left handed when they spin anticlockwise when viewed from the stern looking towards the bow and right handed when they spin clockwise when viewed from the stern. So what you want is either an M4 30mm left or right handed prop depending upon the direction that your motor spins.
True Lifeboat Nutter!!
RaaArtyGunner
Re: Propeller
« Reply #10 on: January 08, 2011, 10:18:29 pm »
Ben
Ben,
If I have got it right, what is being said is, it doesn't matter whether the M4 30mm prop you buy is an, M4 left or M4 right handed prop they will both fit onto your M4 prop shaft.
You then have to decide if you want/need your prop turning left or right, as has been mentioned. :-)) :-)) :-))
modelboatbits
Re: Propeller
« Reply #11 on: January 10, 2011, 10:51:58 pm »
Hi, Ben
If your props turn to the left ( anti-clockwise ) then you require a RH Prop M4 thread
See photo below
Thanks  Steve
Lord Bungle
Re: Propeller
« Reply #12 on: January 11, 2011, 12:19:53 am »
Hi Ben don't worry about the thread :) stick a locking nut next to the prop and a squirt of locktite or something similar at it won't come undone. as for the pitch don't worry about that to much either, you can allways reverse the direction of the motor if you discover it runs backwards on a trial run
Pat Matthews
  • Get your boats wet!
    • Matthews Model Marine
Re: Propeller
« Reply #13 on: January 11, 2011, 12:27:12 am »
And just for fun, note that the traditional definition for prop handedness is reversed in the States... makes ordering fun when you don't know which system is being used!
And we flip our light switches UP for on, too...
Pat Matthews
Get Your Boats Wet!
RaaArtyGunner
Re: Propeller
« Reply #14 on: January 11, 2011, 02:22:48 am »
Yes and you also drive on the wrong side of the road     O0 O0 O0  {-) {-) {-)
Roadrunner
Re: Propeller
« Reply #15 on: January 11, 2011, 08:13:49 am »
bad bad advice, it takes 2 mins to make an effort to find the right prop....
Ben Im gonna link you props that will do the job, take your pick. don't just use a 5m threaded prop on an m4 shaft and hope the thread lock holds, it won't !
try these.
http://www.cornwallmodelboats.co.uk/acatalog/R160-M4.html  brass 3 blade (top two on page m4 30mm rh or lh)
http://www.cornwallmodelboats.co.uk/acatalog/plasticm4.html plastic 3 blade (top two on page m4 30mm lh or rh)
don't worry if you pick lh or rh, this will just dictate the which way you wire the motor to turn clock wise or anti clock wise, in a single shaft vessel, only time to concider lh rh props is when building twin, tripple, or quad shaft driven boats  :-))
Re: Propeller
« Reply #16 on: January 11, 2011, 08:31:41 am »
Loctite will probably  test OK at the lakeside :-)) :-))
Middle of lake  :(( :((
Lord Bungle
Re: Propeller
« Reply #17 on: January 28, 2011, 09:55:31 am »
try these.
oppps my boo boo thats what happens when typing 1/2 a sleep  {:-{ meant to say screw,
Re: Propeller
« Reply #18 on: January 28, 2011, 12:00:47 pm »
I've used my nail varnish in the past!   :kiss:
Sets solid but will break free only when forced.
RaaArtyGunner
Re: Propeller
« Reply #19 on: January 28, 2011, 08:08:50 pm »
And the best colour is....................... :embarrassed: :embarrassed:
Re: Propeller
« Reply #20 on: January 28, 2011, 10:01:40 pm »
superglue makes an effective thread lock too
Page created in 0.026 seconds with 17 queries.
