Sorry to be on a downer for a first post but thought the below info might throw some light on the project and a word of warning before the builders of this project get in too deep
1) In Germany they are at issue 27 and sadly already reporting many build problems that will no doubt be encountered here in the UK, that's bad so early on in what is a very long and expensive series.
2) The cost of £700 to collect the 140 issue series is miles out if you want to build the RC version, the RC conversion kit on offer from Hachette costs 169 Euros in Germany which is about £115. You will also need to buy a battery pack & charger, plus the obvious quantity of glue & paint etc, in issue 18 they are now talking of the use of a muslin/gauze bandage to seal/strengthen the inner sides of the Hull, this is also not supplied either!
I would hazard a guess that you might not see much change out of 1k to build the RC version
The big concern for the RC builder's is that from the outset there is no mention to use a waterproof PVA glue such as Aliphatic resin, issue 1 supplies a nice pot of standard PVA glue which is great for the static build but totally unsuitable for an RC buld....unless that is you want it to replicate the demise of the original ship
The word via Germany is that this seriesl was only intended to build as a static display model, it was a last minute Hachette thought to give the choice of also an RC version.
This seems to back-up the available info, there is no mention of an RC version on the Hachette web site and only brief snippets of info via the backing boards that come with issue's 1 & 2 and a pull out model info sheet, neither is there any word or photo in the first three mags that suggests an RC version, hence the errors now coming to light which am sure will only grow along the way ::)
The quality of wood parts supplied via Amati are good but the marriage between static display & RC version seems frought with problems for this series, so if you are to build the static version then build away warily as suspect there are hidden problems there too, but if it's the RC route then anticipate a whole load of future headaches and complaint call's to Hachette >:(
