Pages: 1 ... 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57   Go Down
Author Topic: Build the Bismarck - a "Hachett" job?  (Read 990928 times)
Traff
Re: Build the Bismarck - a "Hachett" job?
« Reply #1375 on: February 24, 2013, 05:12:30 am »
Thank you very much.  Been on the go with it for about 5 years but have been away for a couple of years with it "laid up".  Wish I hade come across this site when I started, would have saved me a lot of angst and gery hair  ok2  Looking forward to finishing it soon then getting y teeth into the Hood.
jimmy
« Reply #1376 on: March 07, 2013, 06:40:31 am »
where can i order back issues
Martin [Admin]
« Reply #1377 on: March 07, 2013, 11:26:16 am »
max42
« Reply #1378 on: June 12, 2013, 07:48:43 pm »
just be aware they will have very few episodes left  :((
henly1234
« Reply #1379 on: July 31, 2015, 09:11:23 pm »
Anyone ever finish this, I did a job recently and when I entered the property, I saw the chap had two part finished models, one the Titanic and the other the Bismark, I'd never seen either of them before and when I queried them he said he could not do any more to them, so i asked what he intended to do with them and he offered me the lot including all the issues of the mag and parts etc, for both ships for free.
So I've now got another model (Bismark, I farmed the Titanic out) sitting on my shelf to be finished.
Anyone who wants the mags is welcome to them, they are complete in binders, I will never read them and I don't need them for the build, of course I would want them picked up or post and package supplied.
« Last Edit: July 31, 2015, 09:16:23 pm by henly1234 »
Life is like a child's shirt, Short and full of S**t,
(in remembrance of an old skipper of mine)
Martin [Admin]
« Reply #1380 on: July 31, 2015, 09:45:11 pm »
Loads have been finish and some to a very high standards!
See:
http://www.partworkmodels.co.uk/phpBB3/
TheLongBuild
  • Build em, and play hard..
« Reply #1381 on: July 31, 2015, 09:49:17 pm »
See:
 :police: :police: 8) 8) >>:-( >>:-( :police: :police: :} :}
Jjdsplace
« Reply #1382 on: October 14, 2015, 07:56:58 am »
Looking good
« Last Edit: October 14, 2015, 08:01:06 am by Jjdsplace »
imsinking
« Reply #1383 on: October 14, 2015, 09:13:01 am »
? ? ?  %)  Yeah Martin . . . what happened to your BISMARCK ? I joined the forum many tides ago as you stopped listing the work on the main home page and said "continuing on the forum" there's been zilch since , is it on the shelf / in the bin / or gone to a good home ?  <*<
Bill
« Reply #1384 on: October 14, 2015, 09:39:24 am »
I think it has like its counterpart SUNK WITHOUT TRACE
« Last Edit: October 14, 2015, 09:41:12 pm by Peter Fitness »
DJWaust
« Reply #1385 on: March 01, 2016, 08:49:44 am »
Hi all, I have just joined the forum, as I have restarted my Bismarck build after many years of having put it aside.
Martin [Admin]
« Reply #1386 on: March 01, 2016, 09:56:29 am »
Ooooh! This should be good!   :-))
DJWaust
« Reply #1387 on: March 01, 2016, 10:53:57 am »
Well yes I do hope so.
I am using 3X10mm balsa strips to add between the ribs so as to have a better base for the planking.
Martin [Admin]
« Reply #1388 on: March 01, 2016, 11:46:41 am »
Ah! You're fitting an armour belt!
    ok2
TheLongBuild
« Reply #1389 on: March 01, 2016, 12:33:38 pm »
    ok2
Did you not  fit one on yours Martin  {-)
Martin [Admin]
« Reply #1390 on: March 01, 2016, 12:51:34 pm »
No, I was going to build mine as a Greenpeace conversion!    %)
DJWaust
« Reply #1391 on: March 02, 2016, 03:00:24 am »
    ok2
I thought it might be a bit better than glue and gauze. Will add about 120 grams to the mass. Given a max displacement of 6250g +/-10g will still need 2500g ballast.
I have read through your build as far as it went and for me when faced with the planking some 6 years ago I stopped the hull with 12 strips of the 1st layer on.
I continued with deck and superstructure for odd hours here and there for some 6 months. Other things got in the way, a proper place to build, work, home projects (including construction of a garage) and life matters as many others have faced.
BTW Why all the verification checks?
« Last Edit: March 02, 2016, 05:08:03 am by Martin [Admin] »
Martin [Admin]
« Reply #1392 on: March 02, 2016, 05:09:25 am »
Verification is only for anyone's first 5 posts.... to discourage spam-bots!  >:-o
DJWaust
« Reply #1393 on: March 05, 2016, 01:45:10 am »
And so on go more planks over the balsa and ribs.
Note another small change from the assembly instructions: I inserted the shafts before planking.
I could not see how I could drill holes after planking was done.
DJWaust
« Reply #1394 on: March 05, 2016, 01:47:23 am »
Next plank. Hmmm needs trimming.
DJWaust
« Reply #1395 on: March 05, 2016, 01:49:08 am »
Glued and pinned.
DJWaust
« Reply #1396 on: March 05, 2016, 01:50:33 am »
Lets see how that looks with the next plank and some sanding.
DJWaust
« Reply #1397 on: March 05, 2016, 01:53:41 am »
And a bit farther forward on the same side.
Yeah I think that's OK.
Martin [Admin]
« Reply #1398 on: March 05, 2016, 04:16:17 am »
Looking good!
 What glue are you using?
DJWaust
« Reply #1399 on: March 05, 2016, 05:45:54 am »
Polyurethane glue for this stage of the planking. It foams and I cut back the foam.
I assembled the frames with external grade PVA. I am swapping to aliphatic resin (titebond 3) for the rest of the superstructure frames. I might use the titebond for the second layer of planks and avoid pinning - use rubber bands?
Pages: 1 ... 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57   Go Up
