Derek,
I think we are talking about different things here, we started out here by Mick describing a grub screw as a taper pin which he clarified.
There is no need for a taper pin to be used on the sheave of the Stevenson reverse gear as the grub screw allows the rotation of the sheave for timing adjustment.
Mick prefers the pointed grub but I only use hollow point grubs.
If a taper pin was used it would be thro' the sheave collar and right thro' the shaft and taper reamed making adjustment impossible.
In the pic of a recently built D10 with Stevenson reverse gear you can see the grub screw in the sheave which when loosened, the sheave can be rotated for timing adjustment.
This pic is further advanced and you can see the grub screw on the sheave just behind the worm gear.
Here is pic of a 1/4"dia grub and a 2" taper pin. With a 6 ba grub screw tapped into the sheave all that is required is the grub to be loosened and the timing adjusted, I used to be able to purchase 1/8" long x 6 ba grubs but the only small size I can get now is 3/16" long.
If a taper pin is used it is impossible to alter the adjustment of a collar or any other item slid onto a shaft other than rotating the item to the setting require bore a new hole at say 45% and re-reaming the hole, bearing in mind that to keep the object in the same position you will drill into the old hole.
So are we on the same wavelength?, after 42 years in the engineering industry would you please describe how to say adjust a collar on a shaft by re-reaming the hole.
So not sure if we are talking about the same thing but would like to hear how it's done.
Thanks for taking the time to answer.
George.
