Pages: [1] 2 3   Go Down
Author Topic: MAKE THIS CONTINUOUS SMOKE GENERATOR FOR RC SHIPS..AT HOME...  (Read 19048 times)
rathikrishna
« on: January 22, 2011, 05:42:47 am »
Good morning my all respected  loving and caring Friends...as i started my work on my X bow tug, i found an  amazing device on that craft, is its exhaust system,on the port side ,over the canopy...it looks like a diamond necklace on a neck of a beautiful woman...enchanting...but i never copy it, but,will add some imagination,but will be stunning..so sure i need some smokes from it..., i shared you all my puffing smoke generator, but it is not appropriate here, as it puffs..here i need a continuous smoke trace...and in a mild manner..so i turned again to my drawing board..no..this time,i never burned my brain much..because i already done one...but yes..you are right...a cup of coffee...ommm...yummyyyy....and ideas...!!!
rathikrishna
Re: MAKE THIS CONTINUOUS SMOKE GENERATOR FOR RC SHIPS..AT HOME...
« Reply #1 on: January 22, 2011, 05:43:46 am »
its too easy to make one...here we are not using any battery, hazardous chemicals...no resistor wires...no mess...and very less in weight...compact...and can go for any size, can fix anywhere in our craft...and can take smoke through anywhere as we needed...simple to make...elegant...all from handy things around us...but it never shows any head weight..it will smoke up a craft from simple diesel boat, to a ultra powered war ship...and the main advantage of this kind of smoke generator is , the ever divine smell, from the incense sticks...just feel of standing to an Althara, of a Church, or on the  Sreekovil of a Temple...so our craft will graced...
rathikrishna
« Reply #2 on: January 22, 2011, 05:44:45 am »
  now, the Fig 1 shows a piece of a pvc pipe, its inner diameter is mere 1 inch, and we can go for a big one, but see this, and asses its rate of working,and can go for bigger...we can cut a piece of pipe simply...we can also go for anything like in this shape, a plastic lid,or a part of a can..anything...but make sure, its width is about 8 to 10 mm ....
rathikrishna
« Reply #3 on: January 22, 2011, 05:45:24 am »
take a brass tube, is not essential, can use plastic, metal anything with you...i used a tube from a old antenna of a pocket radio.....
rathikrishna
« Reply #4 on: January 22, 2011, 05:45:59 am »
make a oval hole on the pipe, by heating a screw driver over the gas burner..or with any tool with you...clean the mouth with sand paper....
rathikrishna
« Reply #5 on: January 22, 2011, 05:46:28 am »
 cut, a piece from the tube, and make sure it is almost 1 inch at least...and cut, or grind its one end as you see here...
rathikrishna
« Reply #6 on: January 22, 2011, 05:46:56 am »
 now, fix it on to the oval hole on the pipe..make sure the seating is almost perfect, and not in to inside of the pipe...
rathikrishna
« Reply #7 on: January 22, 2011, 05:47:25 am »
fill all gaps with epoxy putty, or anything that with you...even white glue,will do the job...
rathikrishna
« Reply #8 on: January 22, 2011, 05:48:04 am »
now , body of the smoke generator is ok...find a motor for this..remember..here we do not need any powerfull motor...we need only a toy motor,or a motor from a walkman..must within 200 ma..so it will not affect the battery life...if you do not have any less power motor, you can still use a motor from a taperecorder, or from a record player, by taking off its speed controller...a 4.7 ohms, or 10 Ohms 1 watt resistor also help to reduce the consumption of the motor...
rathikrishna
« Reply #9 on: January 22, 2011, 05:48:57 am »
 cut out a circle, from 1mm foam board, that must be greater than the pipe we use...make sure its centre by Compass...and fix motor there with some drops of super  glue...BLUMMMM....its there...once again we must thank for the super glue...
rathikrishna
« Reply #10 on: January 22, 2011, 05:49:35 am »
make a second circle that must fit within the inner dia of the pipe...divide it in to 8 portions.and insert on to the shaft of the motor...
rathikrishna
« Reply #11 on: January 22, 2011, 05:50:04 am »
 make an impeller as shown, by glueing foam board strips on it...after making sure, drop some super glue all around, including motor shaft...
rathikrishna
« Reply #12 on: January 22, 2011, 05:50:32 am »
 now fix the pipe as shown..make sure the impeller is not  jamming anywhere...
rathikrishna
« Reply #13 on: January 22, 2011, 05:51:04 am »
cut a thirdth circle,as like as the 1st one, but make a hole at centre, and fix a cap, or a piece of a pipe as shown to increase the venturi pressure...
rathikrishna
« Reply #14 on: January 22, 2011, 05:51:37 am »
from this angle its clear...we can add a simple net, to its mouth, if we afraid, of pulling in anything from the crafts...
rathikrishna
« Reply #15 on: January 22, 2011, 05:52:13 am »
 now time to check...connect the pump, to a esc, or to a battery pack...and make sure it is blowing air...and make sure, the direction, of the motor , it must be faced to the pipe that we fixed at first...
rathikrishna
« Reply #16 on: January 22, 2011, 05:52:49 am »
 mark the rotational direction, so we will get a idea later...
rathikrishna
« Reply #17 on: January 22, 2011, 05:53:22 am »
fill all gaps with epoxy putty or by anything, if you are too concered to weight, you can simply grind off excess material from it....now we have a simple CENTRIFUGAL BLOWER....
rathikrishna
« Reply #18 on: January 22, 2011, 05:53:55 am »
our next step is finding a plastic bottle, or  PP, brass, steel bottle with a lid, with screw,and its size is all according to the crafts...but remember...a long bottle will hold a lond insence stick, so a longer time smoke....make a hole to the size of the tube that we fixed on to the pump,just above the lid line,and paste a piece of foam board over there...
the bottle must be upside down....
rathikrishna
« Reply #19 on: January 22, 2011, 05:54:30 am »
after setting the glue, fill all gaps with surely, epoxy putty, or metal paste, or car body putty...
rathikrishna
« Reply #20 on: January 22, 2011, 05:54:59 am »
leave the bottle to dry...within that time, take the lid, an cut a circle from an aluminium sheet,thin is enough, that within the lids circumference.
rathikrishna
« Reply #21 on: January 22, 2011, 05:55:25 am »
 cut a piece from same sheet,and make a structure like this, its our stick holder....
rathikrishna
« Reply #22 on: January 22, 2011, 05:55:54 am »
take a piece of perforated aluminum sheet, and its width must be within the height of the bottle....
rathikrishna
« Reply #23 on: January 22, 2011, 05:56:24 am »
make a structure like this and glue it on to the circle as shown...this works as an atomiser, and also as a heat sink....and also  as a ash tray....
rathikrishna
« Reply #24 on: January 22, 2011, 05:56:58 am »
 now fix the pump as shown to the bottle,and apply glue....
Pages: [1] 2 3   Go Up
Page created in 0.139 seconds with 19 queries.
