Pages: 1 [2] 3 4   Go Down
Author Topic: Detailed build of F1 Tunnel,Drawings to finished product  (Read 14845 times)
F1 madness
Re: Detailed build of F1 Tunnel,Drawings to finished product
« Reply #25 on: January 31, 2011, 08:51:34 pm »
 Hey guys made some changes still not finished yet got some trimming to do etc.
Im gonna try a newer modern design as suggested,just hope it turns out ok.
Im aiming for somthing similar  to this
steamboatbob
« Reply #26 on: February 01, 2011, 10:31:29 am »
Hey Bob
I use a bandsaw saw now,but still do some of it by hand :D
I can only dream of having proper tools for the job atm im stuck with a scoring knife and a jigsaw but the big bandsaw at work is ok if it decides to let us work on it (i have to say it it like some of the older members of boat clubs. Very temperamental)
F1 madness
« Reply #27 on: February 01, 2011, 05:00:36 pm »
 And some more pics LOL
Finished trimming the new front bulkhead after changing the design of the front
Cut the first piece for the top of the nose,gotta make another couple moving further forward to support and add some strength in the nose,im going to add a slight curve top to the nose aswell.
I will remove the piece between the 2 once iv finished as this is where the fuel tank will sit
gregk9
    • Chasewater Model Boat Club
« Reply #28 on: February 01, 2011, 06:06:00 pm »
heres a bit of future thinking,  Any thoughts on where you are planning to test this one daz?
With the I/c power unit onboard, it will rule out Chasewater.................
Best wishes.
Steve. G.
F1 madness
« Reply #29 on: February 01, 2011, 08:01:19 pm »
Hey steve it only rules out chasewater for now once the main lake is refilled i should be able to run on there already thought of that 1,up till then iv got somewhere i can run it so for now ill use that :-))
F1 madness
« Reply #30 on: February 01, 2011, 08:01:38 pm »
Started cutting out the under wing pieces,nice tight fit just gotta trim the ends once iv marked them out
gregk9
« Reply #31 on: February 01, 2011, 08:24:23 pm »
Hi Daz, kindly remember, that once the dam  and main lake repairs are completed, it could take  quite some time for the lake to refill, [anything up to 2-3 years] then, CMBC still have to negotiate with the sailing club for permisssion, its not a foregone conclusion it will be granted yet, so its good you dont have all your eggs in one basket !
[ha ha]
Best wishes.
Steve. G.
F1 madness
« Reply #32 on: February 01, 2011, 08:30:13 pm »
[ha ha]
I cant see there being a problem as for refiiling the lake ill get my hose out  {-) {-)
gregk9
« Reply #33 on: February 01, 2011, 08:35:25 pm »
hope your place isnt on a water meter !!!!!!!!!!!!!!!!!!!!!
Best wishes.
Steve. G.
F1 madness
« Reply #34 on: February 01, 2011, 09:56:23 pm »
Just finished cutting and sanding the centre wing pieces so another test fit and there perfect fit
Shall mark out the sponson bottoms now i think
F1 madness
« Reply #35 on: February 03, 2011, 08:33:39 pm »
Hey guys got some more done,been concentrating on the sponson tips and also changed the profile of the top deck
Managed to pick a sheet of 3mm ply today for skinning the sponsons so will start cutting them out next
F1 madness
« Reply #36 on: February 10, 2011, 11:09:38 pm »
Well guys heres some pics as promised,i must say im quite pleased with myself next to nothing mods to get it fit in apart from chop a bit of the tops of the rear bulkheads to clear exhaust
gwa84
« Reply #37 on: February 11, 2011, 01:28:20 am »
looking good  :-)) O0
F1 madness
« Reply #38 on: February 11, 2011, 08:06:24 am »
Cheers bud i can start thinking about getting it together now and glued :-))
F1 madness
« Reply #39 on: February 11, 2011, 10:53:39 am »
Now for CG adjustments and fixing the mounts.
Iv just brought 16 of these little pieces,im gonna work out the CG and have 4 different placments allowing easier adjustment,im also gonna put some epoxy on them the use some fibreglass cloth and epoxy to hold them in place,the 1 not being used will have some push in seals so should any water get in it wont fill the cavity up.
F1 madness
« Reply #40 on: February 12, 2011, 12:47:15 pm »
Hey guys,just playing around with some settings For CG etc and will hopefully have some more pics later and start getting it glued together and cutting out sponson skins
triumphjon
« Reply #41 on: February 12, 2011, 10:20:04 pm »
thats starting to take shape really well , i have fond memories of these style of cats , as a very young person i lived next to the bristol floating harbour , full sized powerboating every year ! !
F1 madness
« Reply #42 on: February 13, 2011, 11:57:30 am »
The good old days off racing them round bristol docks :-)) :-))
Hopefully start cracking on with it today and get it looking somthing like {-)
F1 madness
« Reply #43 on: February 14, 2011, 09:13:42 pm »
Hey guys,started gluing the bulkheads and inner sponsons together,making sure their upright,and square
Also while glue drying been drilling and fitting the blind nuts/captive nuts for the mounts to screw in to for the engine and test fit again LOL
Will post some pic soon,just gonna finish glueing the rest of framework
Perkasaman2
« Reply #44 on: February 15, 2011, 12:52:40 am »
Fascinating stuff -  :-))
gwa84
« Reply #45 on: February 15, 2011, 02:02:42 am »
looking good as always ime liking the way you've mounted the engine hadn't thought of using blind nuts before an idea ai may pinch at some point in the future  :-))
F1 madness
« Reply #46 on: February 15, 2011, 09:37:46 am »
martno1fan
« Reply #47 on: February 15, 2011, 09:39:09 am »
Just be sure to spray those captive nuts with corrosion x or grease them because they rust,keep up the good work mate shes coming along niceley.
Mart
F1 madness
« Reply #48 on: February 15, 2011, 09:40:54 am »
Cheers bud,should really start taking shape soon,i chose the blind nuts to keep the center pod as streamline as poss which will look alot better once completed :-))
F1 madness
« Reply #49 on: February 15, 2011, 09:42:36 am »
Mart
Will do mart,shes starting to take shape now,looking forward to getting it completed :-))
Pages: 1 [2] 3 4   Go Up
