Pages: 1 2 [3] 4   Go Down
Author Topic: Detailed build of F1 Tunnel,Drawings to finished product  (Read 25449 times)
F1 madness
Re: Detailed build of F1 Tunnel,Drawings to finished product
« Reply #50 on: February 15, 2011, 09:42:55 am »
Hey fellow followers LOL
Got some of it glued together,left it over night to fully cure and starting to take shape again,gonna concentrate on centre pod and add another piece to the transom for some extra strength.
F1 madness
« Reply #51 on: February 16, 2011, 11:44:53 am »
Hi guys,got abit more done,glued the tunnel wings sections in,sorted out the nose and glued the top on and laminated another piece on the transom.
Started cutting out sponson sides and also gonna start on the center pod floor
gregk9
    • Chasewater Model Boat Club
« Reply #52 on: February 16, 2011, 12:00:02 pm »
You sure you not gonna need a pilots license for this one Daz ?  [ha ha].
Looking good matey, presume you might put some polystyrene blocks on the sponsons? or might you be using expanded foam,  simply for boyancy, plus may help stop them flexing so to speak.
Best wishes.
Steve. G.
F1 madness
« Reply #53 on: February 16, 2011, 02:25:39 pm »
Cheers steve,no i wont need a pilots license.
I will add somthing in the sponson just not sure yet what will be best,i'll cross that bridge nearer the time,for now just concentrating on getting the sponsons skinned and the pod floor,i will then reinforce the insides with some epoxy and cloth strips :-))
F1 madness
« Reply #54 on: February 16, 2011, 05:41:37 pm »
Got some more done started added the skins to the 1 sponson,will cut and add ride pad with step then start the other side:D
Back to sanding again LOL
F1 madness
« Reply #55 on: February 17, 2011, 11:35:01 am »
Here we go again another update.
Got the ride pad fixed down on the 1 sponson with a step
Also got the sponson side glued on the opposite side,will concentrate on finishing the sponsons 1st then sort out the centre pod floor.
F1 madness
« Reply #56 on: February 17, 2011, 05:35:51 pm »
Got the bottom of the other sponson skinned now,just gotta line up and add the ride pad and sort the step
More pics soon LOL
F1 madness
« Reply #57 on: February 17, 2011, 07:54:47 pm »
Some more pics guys,the sponsons are complete,just need a good old rub down.
Gonna start the pod floor tomorrow,off to wet sand another project
F1 madness
« Reply #58 on: February 18, 2011, 02:19:17 pm »
Got abit more done,got half the pod floor glued on,worked out the where the stuffing tube will exit and made a small cut out.
Test fitted the engine again to triple check the clearances,plenty of room
F1 madness
« Reply #59 on: February 18, 2011, 05:56:38 pm »
Finally finished pod floor and cut out for the stuffing tube to pass through.
gregk9
« Reply #60 on: February 18, 2011, 11:39:08 pm »
Pardon my ignorance Daz, but is the engine water or air cooled, I've forgotten !
builds certanly progressing well !
Best wishes.
Steve. G.
F1 madness
« Reply #61 on: February 19, 2011, 11:02:25 am »
Hi steve the engine is watercooled.
Its getting there slowly :-))
F1 madness
« Reply #62 on: March 02, 2011, 10:58:10 am »
Finally got some pics.
Iv used 2oz glass cloth in the sponsons with epoxy and added some foam tubes.
Also got top decks cut and test fitted
Just gotta get the surfaces sanded now make sure the top decks sits perfectly on the framework
F1 madness
« Reply #63 on: March 02, 2011, 03:48:32 pm »
Got 1 of the top decks on,also laminated a of birch ply on the rear of the sponson,iv started sanding the edge down to strip to finish it off.
F1 madness
« Reply #64 on: March 02, 2011, 07:56:55 pm »
And some pics
Got the other top deck on now aswell,so only got side strips to sort out then the canopy.
phillnjack
« Reply #65 on: March 03, 2011, 01:36:42 am »
Its getting closer and closer   :-))
now whats that engine almost hiding away up just behind the silver boat in the corner    :P
phill :-))
F1 madness
« Reply #66 on: March 03, 2011, 09:08:17 am »
That my friend is the RCMK rear exhaust power plant for this project :}
gregk9
« Reply #67 on: March 03, 2011, 05:42:18 pm »
Hope You & the family are  feeling better now daz, presume the heating crisis is sorted now. [i Hope].
Some of the Chasewater MBC crew are off to the boat show Saturday, so pool should be reasonably quiet if you fancy doing some more testing Daz. I'll be there and maybe a couple of the other lads . I'm working am and sunday am, so cant go to the show :(
Best wishes.
Steve. G.
F1 madness
« Reply #68 on: March 03, 2011, 06:00:41 pm »
Hi steve,the heating system is being sorted as we speak,took them a whole week >>:-(
Yeh i probably will as iv managed to repair those lipos so all is good again,iv modded the F1 with new outboard,but had to change the motor for now.
Also want to run the 500 cat and connor wants to run the saga so weather depending ill be there. :-))
What time will you be going down %)
gregk9
« Reply #69 on: March 03, 2011, 06:06:43 pm »
Hi Daz,
I should be there around 1.30 - 2pm matey.
Pusher tug n fireboat  this time round !
My latet build [RMAS moorhen in biuld blog] is coming along fine, but waiting on steve to supply me with a pair of Korts, so i can setup the powerplant driveline/
had loads of fun with myhobbystore as their  sub contractor/supplier of the styrene sheets decided to cut them all "by hand" without a single square edge to em. so did my "usual thing", complained like **** and they are sending some replacements out.
Best wishes.
Steve. G.
F1 madness
« Reply #70 on: March 03, 2011, 06:16:38 pm »
Cool ill hopefully see you there.
Dont blame you the styrene business i wouldnt of been happy either.
See you then bud
Rgds Daz
Hi Daz,
F1 madness
« Reply #71 on: March 03, 2011, 11:07:49 pm »
got some done on the canopy,not finished yet still got some shaping and to do but so far looks ok.
F1 madness
« Reply #72 on: March 04, 2011, 10:51:56 am »
F1 madness
« Reply #73 on: March 04, 2011, 04:27:31 pm »
Just having a play around with some ideas LOL
What you reckon
samuelmerry
« Reply #74 on: March 08, 2011, 04:09:42 pm »
I have just one question, what lives in your big glass tank?????
Pages: 1 2 [3] 4   Go Up
