Just got a Krick 'Anna' steam pinnace kit, complete with engine from A Model World as an Introduction to model steamboating. The box contents are of good quality, as one would expect from germany, what with their reputation for precision and all. The hull is a chunky little ABS vacforming 610mm x 260mm. The wooden parts are laser cut from good quality veneered ply ranging in thickness from 7mm to 1.5mm, a stand is also included, again in 7mm ply. A bag contains propshaft, steering gear, plastic prop and sundry fittings and there is a pair of flags and Anna decals (these will not be used as I am going to name her 'Minnie' after my little yorkie who can be seen supervising the unpacking for photographic purposes.
The engine was packed in a separate box, unfortunately no photos were taken of the parts as I could not wait to get my sticky little fingers burnt and I had it assembled in no time. The boiler comes ready soldered so assembly is a 'bolt together job' the engine is a single cylinder, double acting piston valve engine that will run in either direction, although it is not self starting. Firing is by means of 'Esbit' tablets or similar, but these are not supplied. The engine runs well and seems to be quite powerfull for its size ( goes like the clappers, to coin a phrase
