Author Topic: rudder mounting  (Read 2987 times)
rescue
rudder mounting
« on: February 25, 2007, 05:20:38 pm »
hey I 'am building a Mersey lifeboat and I'm wondering how to make a ruder fitting trow the hull for home made rudders?
AL suggestions are welcome
Edwin
catengineman
Re: rudder mounting
« Reply #1 on: February 25, 2007, 10:13:33 pm »
Edwin
Hi Edwin,      I don't know what size you have for your rudder shaft but you could try a length of brass or copper tube that fits over the shaft snugly.  I will add be sure to make the top of the tube finish higher than that of the "water line" or ingress of water will probably occur.  Bonding the rudder tube to the hull with an epoxy resin should be OK with most hull materials.
Richard,
Re: rudder mounting
« Reply #2 on: February 26, 2007, 01:19:24 am »
Edwin
Richard,
To add to Richards entry. The small brass rudder tube can run through a wooden block, adding strength when it is epoxy glued to the hull.
HS93 (RIP)
  • I cannot spell , tough
Re: rudder mounting
« Reply #3 on: February 26, 2007, 01:32:36 am »
Any chance of a picture of the parts or the bit of plan or a bit more about the hull.. Im shure there are plenty of people who will post pictures when they get a bit more info   peter
rescue
Re: rudder mounting
« Reply #4 on: February 26, 2007, 09:09:00 am »
the hull is still under construction and is filed whit polystyrene
it Will be don whit gpr as soon as possible
so the total space that i have  to operate in will than be seen i think it is around 5cm high
the rudders haven't been made yet it Will be from Wood whit a schaft trow it
but no details jet i first want som info how to make a propper rudder setting
Edwin
Re: rudder mounting
« Reply #5 on: February 26, 2007, 10:02:09 am »
Here is the way I did my shafts . I have fitted tubes which should be higher than the water line
Cheers...Ken
rescue
Re: rudder mounting
« Reply #6 on: February 26, 2007, 04:35:45 pm »
would a bit of grease help to prevent water from entering or Will this be to muts resistend?
Edwin
catengineman
Re: rudder mounting
« Reply #7 on: February 26, 2007, 08:26:01 pm »
HI Edwin,
 Yes grease inside the tubes will help but the important thing is to have good fitting rudder shaft to rudder tube sizes, also fitting an 'O' ring over the shaft will help a little but the hight of the tubes must be above the water line.
Are you making the complete rudder system from scratch? or will you concider some shop produced parts?
Richard.
edible_engine
Re: rudder mounting
« Reply #8 on: February 26, 2007, 08:39:48 pm »
i made the rudder on my boat from scratch its to close fiting tubes of ks brass
rescue
Re: rudder mounting
« Reply #9 on: February 26, 2007, 08:58:39 pm »
i wil make them totaly out of scratch to keep the costs down
edwin
